Question about Ovens
Oven takes a long time to heat up and wont go past 350
I have a GE electrical oven (model jsp50gn) and it is not heating up properly. It takes about an hour to get to 300-350 and will not go past 350. The boiler and stove top works fine. I tested the element, and it was a steady 22 ohms.
Any ideas? I want to fix this before thanksgiving!
  • 1 more comment
  • ukuwabara Nov 25, 2008
    The bottom element does not get any power. When I put it on Bake, the top element gets hot...
  • Anonymous Feb 05, 2009
    My GE Profile oven will not reach the set temp. The beeper indicates it is heated to the set temp but it actually is not.
  • thuroeboat Feb 05, 2009
    My GE Profile oven will not reach the set temp. The beeper indicator goes off but the oven is not hot enough and does not reach the set temp.
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
  • 126 Answers
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Posted on Dec 14, 2007
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
Posted on Dec 27, 2008
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Ge oven will heat up then the pre heat will beep then oven shuts off and the time light will flash 0
heatman101
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
My oven wont heat up past 200 degrees. Suggestions
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Mar 04, 2011 | GE Monogram® ZMC1095BFBB /...
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
I have a brand two month old GE 27" wall oven. It takes a very long time to pre-heat, sometimes up to 30 minutes for 350. Any ideas? Is this normal?
check your power connections, do you get 240 volts between red and black, 120v red/black to white? at outlet and in unit
Jul 05, 2009 | GE JKP30BMBB 27" Built-in Single Electric...
GE Profile JT952 Double Wall Oven doesn't heat up adequately
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Dec 28, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
575 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
