Question about Biostar K8M800 Micro AM2 Motherboard
I cant use any flash drive on my pc
My usb port cant read flash drive or removable disk but printer, keyboard, or mouse are fine. how can i fix it?
  • mojaja Nov 26, 2008
    is the service pack 2 included in the xp installer?
    Sergeant:
  • 177 Answers
If you are using XP and don't have Service Pack 2 intalled then try to install Service Pack 2.
Posted on Nov 25, 2008
  • spacewalker Nov 27, 2008
    Service Pack 2 installer is not inbuilt with normal XP installer. To make sure about the version of xp installed in your computer, Right click on My Computer and click Properties. It will show the version
Connecting usb Flash drive to ncomputing l300 client
The flash drive may need to be formatted. I hope this helps. Go to PC settings and look for your usb port which shows your flash drive and right click your mouse or touch pad and click format. Thank you and have an enjoyable day. Leave feedback.
Jul 14, 2016 | NComputing L300 Terminal Computer PC...
Cannot conect with usb
Try the USB memory-stick in another computer.
If it does not work, then the memory-stick is broken.
If it does work, then the memory-stick is OK.
Try a USB mouse or USB keyboard in another computer, to prove that the device works in that computer.
Try the same USB mouse or USB keyboard in a USB port in your computer. Try each USB port.
If the mouse/keyboard does not work, then there's something wrong with the USB ports on your computer, either "hardware" or "software".
Open "Device Manager" in Windows, and check that the software device-drivers for the USB hardware are correctly installed.
Try "reinstall device driver" to see if Windows can repair itself.
Dec 30, 2009 | Electronics - Others
USB and Mouse/keyboard ports dont work
You can buy adapter from newegg.com to convert standard PC mini-din keyboards/mouse to USB.
Oct 27, 2009 | Biostar TFORCE 6100 Motherboard
I have an 8gb san disk and a 4gb hp secure digital disc full of photos. I can't get my computer to open or even recognize either.
1. Have you tried another card reader?
2. Have you tried to read these on another computer?
3. Do you have a printer that has a card reader?
4. Perhaps all your USB ports are v1.1 and the inrerface requires USB 2.0, if so, try the USB ports in use by your mouse / keyboard.
5. Did you check [My Computer] to see if "Removeable Disk" is listed, perhaps as Drive E?
Sep 25, 2009 | SanDisk 8GB microSDHC Memory Card with...
Computer will not find flash drive
Does the flash-drive work on *ANY* computer?
If not, the problem is the flash-drive.
Does your computer have more than one USB port?
Does it work in *ANY* port?
Does a *DIFFERENT* USB-device (mouse, keyboard, printer) work in the USB-port that you are trying to use? If not, the USB port has a problem (either software or hardware).
Sep 16, 2009 | SanDisk Televison & Video
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
New keyboard and mouse set only works plugged into usb ports
You could purchase a 4 port usb hub for less than $30. Leave the keyboard & mouse where they are & use the hub for your other devices. This is probably the easiest option. Hope this helps.
Mar 28, 2009 | Dell Dimension 3000 PC Desktop
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
Flash disk comes up as unknown devices
Try to download some new USB drivers, or update your old one. That may fix your problem.
Sep 05, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
Biostar K8M800 Micro AM2 Motherboard Logo
103 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
