Create a class called employee that includes three pieces of information as instance variable a first name, a last name and monthly salary. Your class should have a constructor that initializes the three instance variables. If the monthly salary is not positive, set it to 0.0. Write a test application named EmployeeTest that demonstrates class Employees capabilities. Create two Employee objects and display each objects yearly salary. Then give each Employee a 10% raise and display each Employees yearly salary again.
    Brigadier General:
  • 10,406 Answers
Nice try!
Find an upper-class student that can give one-on-one tutoring with your homework.
Posted on Dec 02, 2009
Create a program that will the salary, no of hours work, the deduction, total deduction and net pay.
The easiest way to do this is to use Excel spreadsheet.
This is what you need to do.
Create a label at the top of each column as detailed.
Add a employee to each row under Name of employee
Then against each employee add the data and the formula in the relevant cell under each column.
The first column - Name of the employee
2nd column - salary rate per hour
3rd column - hours worked
4th column - gross pay (formula = salary rate X hours worked)
5th column - tax deduction
6th column - other deductions
7th column - total deductions (formula = tax deduction + other deduction)
8th column - net pay (formula = gross pay - tax - total deductions)
At the last row you can include a total for Gross salary paid, total Tax collected etc.
Once you have setup this spread sheet make a copy of it and save it as a template.
You can then copy this template for each new financial year so you do not have to create a new one each year, you only need to make minor changes for new employees, rates of pay etc.
Another way to make a salary program is to use Access Database. You need more skills to do this, but it can provide greater reporting capabilities.
Mar 24, 2011 | Computers & Internet
In c create a class called car having members model no,year,no of doorsand mileage and have member functions to add and modify the members of the car
create a class called date that includes three pieces of information as data members-a month (type int), a day (type int) and a year (type int) in c++
Aug 19, 2010 | Borland Turbo C++ 3.0 Full Version...
How to define variables in flash action script for every movie that i want
Using variables in a project
When you build animations or applications with Flash, there are very few situations in which you don't need to use any kind of variable in your project. For example, if you build a login system, you might need variables to determine whether the user name and password are valid, or whether they are filled in at all.
You can find more information on loading variables (such as name/value pairs) in Working with External Data.
In the following example, you use variables to store the path of an image you are loading with the Loader class, a variable for the instance of the Loader class, and a couple of functions that are called depending on whether the file is successfully loaded or not.
To use variables in a project:
1. Create a new Flash document, and save it as imgloader.fla.
2. Select Frame 1 of the Timeline, and add the following ActionScript to the Actions panel:
/* Specify default image in case there wasn't a value passed using FlashVars. */
var imgUrl:String = "http://www.helpexamples.com/flash/images/image1.jpg";
if (_level0.imgURL != undefined) {
// If image was specified, overwrite default value.
imgUrl = _level0.imgURL;
Apr 15, 2009 | Macromedia Flash Professional 8.0 Full...
Dissappearing spaces when html page handles database data
Mark, it sounds like when you are displaying the data back to check and edit the data, you are not including it inside of quotes.
example:
//query to grab example data
$query="select name,salary from employee";
$result=mysql_query($query)
or die("query failed!");
printf("<input type='text' value='%s'>",mysql_result($result,0,"name"));
printf("<input type='text' value='%s'>",mysql_result($result,0,"salary"));
notice in my example the "value" argument of the "<input>" command the %s for your variable is contained within single quotes.
Apr 04, 2009 | The PHP Group PHP
Create a class called Date in C++
I wrote it for you:
date.cpp
date.h
Remember, this is only a demonstration, so you can learn from it!
Mar 26, 2009 | Computers & Internet
Create an employee class contains following members data members:
class employee
int emp_no;
char emp_name[80];
float Basic;
public:
employee(int no, char *name, float basic)
emp_no=no;
emp_name=name;
Basic=basic;
float int calc_da()
return(Basic*52/100);
float calc_it()
return((Basic+calc_da())*30/100);
float calc_netSal()
{return(Basic+calc_da()-calc_it();}
Feb 28, 2009 | IBM Computers & Internet
Payroll system in DBMS. I don't know what data is to be taken.
Firstly you need to determine/state whether you are using a database application, such as Access, MtSQL or MS SQL and programming them to do create this application, or are you using a programming development tool such as Visual Studio, ASP.NET, PHP or the like, as the solution and guidance will be different for each.
In terms of the data design, you should store the data necessary to identify each employee uniquely and each data point per employee needed to calculate their payroll. You should then store the generic (applys to all employees) such as tax rates, in separate tables and call on it to calculate wages and other paystub data.
For instance, the employee first and last names and tax ID should be a sufficient unique identifier. Create a table for just employees, their names, tax ID, start date, schedule, pay rate, number of deductions, direct bank payment data, etc., and whatever else you decide you need for each employee. You can calculate their wages by multiplying their rate by their schedule and applying the appropriate tax rate and medical/witholding deductions as you go, so calculated data does not need to be stored and consume database space.
You'll likely need a separate table for common data such as tax rates, one for deductions/witholdings, one for holidays, one for vacation accrual rates, one for medical rates, etc. This data if common to employees does not need to be stored per individual, as that would cause redundant replication of data. If the employees are on an hourly rate, rather than a set salary/wage, then you'll need a table of worked hours per employee, akin to their timesheet data. If you use a timesheet/timecard, the entering and storing only the totals and keeping the physical timesheet for backup records should suffice.
Once you design and populate your database as suggested above, then it's a relatively-simple task of calculating the computed paystub data and storing the salient resulting datapoints for the record.
Consider a reporting application, such as Crystal Reports, for your printing needs, as its far easier to configure Crystal or similar product to format reports, paystubs, checks, etc., than coding these from scratch.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Can I get the asswer for the below questions
A book shop maintains the inventory of books that are being sold at the shop. The list has details like author, title, price, publisher and stock position. Whenever a customer wants a book, the sales person inputs the title and author and the system searches the list and displays a suitable message if it is not available. If it is available, the system displays the book details and requests for the number of copies required. If the copies are available, the total cost of the copies requested is displayed, otherwise the message ‘copies not in stock’ is displayed.
Design a system using a class called BOOKS with suitable member functions and constructors. Use new operator in constructors to allocate required memory space.
Nov 16, 2008 | Computers & Internet
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
766 people viewed this question
Alun Cox
David Payne
David Payne
