Question about PANDIGITAL (DPF802) Digital Picture Frame
Can't find photos in built in memory
I can't find the photos i copied from my laptop to the frame's built in memory. when i click photos mode, using remote, it says no photo files.i tried checking files mode but i get the same thing. but when i connect frame to the laptop and navigate pandigital memory thru the laptop, laptop reflect photo files in the digital frame's built in memory. what's wrong?
welcomejee
  • 10594 Answers
SOURCE: Need to get drivers for
Hi, You can check required drivers on Pandigital Support in download section.
Posted on Jan 11, 2009
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
  • 8 Answers
SOURCE: I have a Pandigital photo viewer (piece of ****)
Its probably because it may need a password or it is only for a usb not a usb cable
Posted on Oct 23, 2009
SOURCE: Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Posted on Apr 27, 2010
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
Jul 30, 2011 | Parrot 7-Inch Digital Photo Frame (Red)...
How to copy pictures in digital frame internal memory
http://www.digitaltips.org/imaging/digit... ...
The following items about digital frames are from the link above where you may find additional information.
Memory
Another important feature to consider is how many images you can store on the frame. Most have slots for loading pictures directly from a camera's memory card. Make sure it accepts the same type or types of cards that your camera(s) do, as this will make transferring images to the frame significantly simpler. Also, look for a frame with a large internal (built-in) memory if you plan on loading lots of images for slide shows, videos and so forth.
Connectivity
With all the attention your digital frame will get from friends, family and members of your own household, you'll want to keep it updated with your most recent photos. Having multiple connectivity options can make this task a lot simpler. Most frames can connect to your PC using a ubiquitous USB cable, while Blue tooth and WiFi-enabled frames let you sync wirelessly from laptops, camera phones and cameras that are WiFi enabled. Many WiFi-enabled frames can automatically sync images from PCs on your home network or from photo sharing sites on the Internet, making it simple to keep updated.
If your computer has memory card slots, you can copy from the computer to a memory card.
If there are no memory card slots on your computer, purchase a Targus card reader at Walmart for $8.88 or another brand for less at Ritz/Wolf/Kit camera. Also, they do 3½ x 5" digital prints for 6¢ each on Tuesday and Wednesday.
CAUTION To prevent memory card corruption, keep batteries charged and don't delete. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select then click Stop and OK.
Have just been playing with this and found that it works really well, but you should first format the memory card in the camera because it adds files to the card you will need.
Next, take a picture of something with the camera.
Place the memory card in the card reader and go to My Computer.
Open the memory card and you should see a folder on the left (DCIM) that has your picture. Do not open the MISC folder on the right.
Double Click on the DCIM folder and you should see another folder (e.g.,100HPM417) which includes the name of your camera. Double Click on that folder and you should see the picture you just took.
When you copy from the computer to a memory card, that is the folder where your computer pictures must be copied. You may only be able to copy one picture at a time from My Computer.
One last thing, the file names of your pictures must not have any additional letters or those pictures will not be seen by the camera. Also, the file name format must match the file name of the picture you took e.g., HPIM1903. Rename files to the format of your camera photos.
If you have trouble with this, it may be easier to right click on Start and then left click Explore. Find and select the pictures you want to copy and then near the top left, click the X next to Folders to see a place to select Copy files. You can then select the memory card folder e.g.,100HPM417, that you clicked to see the picture you took and click Copy. You can copy pictures easier with this method.
Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. ...
http://www.google.com/base/a/4210404/D13...
Thanks.
Mar 11, 2011 | Cameras
How do i transfer photos from internal memory to a memory card? finepix z 3x
Press > to enter Playback mode, then press Menu/OK to open the Playback menu. Use up/down to highlight Copy, then press right. Use up/down to select Internal Memory -> Card and press Menu/OK. You can copy one picture (frame) at a time or all pictures (frames).
Apr 29, 2010 | Fuji Z10 Digital Camera
I can't transfer photos from Adobe to digital frame
The Kodak S510 does not have a built-in internal memory. You can hook it up on your computer using a USB cable with a USB OTG connector and copy the pictures from your computer to the inserted memory card or a USB flash drive in the frame.
Also, make sure that your photos are in JPEG format.
Feb 07, 2009 | Kodak EasyShare One Digital Camera
Built in memory full...?
I have new camera ,After shooting 12 photos it's show Built in memoru full and cannot shoot anymore
Jan 23, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
HOW TO PUT MUSIC ON FRAME
I just received a gpx photo frame. I can not copy from my memory card to photo frame. Has built in 1 gig memory
Dec 24, 2008 | Nextar N7 - 7 Digital Photo Frame with...
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
It was my birthday last week , and my boyfriend bought me photoframe (digital) i hav manged 2 set clock, but cant seem 2 figure out how 2 get photo's from my laptop on 2 it , i hav manged 2 use a memory...
hi there
most photo frames don't come with a built in memory so you would need to check the manual.
if it hasn't then you will have to put them all on a memory stick. a 2gig stick will hold about a thousand pikkys. if it has got a built in memory you just need to copy them on to it. post the make and model number and i'll sort it out.
beergut707
Oct 13, 2008 | Philips Cameras
PANDIGITAL (DPF802) Digital Picture Frame Logo
24 people viewed this question
Top PANDIGITAL Photography Experts
LP
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
