Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Cannot watch anything
When I try to use my camera, it does not work. I will record something, go to the VCR mode, try to watch it, but nothing shows. Unlike everyone else here, I do not see a black screen. All the screens are fine and look the way they are supposed to. The problem is all the old videos I have I cannot watch, as if I never recorded anything. This has happened on multiple tapes. I just press play on the LCD but nothing happens. I was reading around, and saw somthing about a switch block. If this might be the solution, then please explain what it is to me. Thank you.
  • 105 Answers
Just head cleaning cassette and play ones
Posted on Feb 10, 2007
Lorex security camera
Coax from camera needs to feed vcr, at line in, line out from vcr goes to input of tv ie av1 av2 video in what have you. go that far and see if it makes sense.Then you can set vcr to record continuous and watch it at same time on tv or monitor.
May 14, 2017 | Lorex Home Security
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Jul 16, 2011 | RCA VR525 VCR
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
VCR into camera
Since it is a Canon XL1S, I don't think that this feature is available (the recording tape to tape) until the XL2 Model. Just in case I am wrong, make sure that you are in VCR mode, and that in the menu options, somewhere there should be an option called Av to DV or something. As for the other part, you have to change what the display shows on the viewfinder. This is also in the menu under display settings, Timecode.
Jul 17, 2007 | Canon GL1 Mini DV Digital Camcorder
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
46 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
