Question about Sharp CD-XP5500 CD Shelf System
Volume My stereo's volume is not working. I can hear the radio and stuff but the volume is not loud. I don't know if a speaker is blown or an amp isn't working. Please help me resolve this issue. I have a Sharp CD-XP5500
  • Anonymous Oct 20, 2008
    i have a radio just like that that makes a bussing noise so I have to unplug it to make it stop HELP!!!!!!!!!!!!!
  • 82 Answers
Check for any blown fuse on the board with the power transformer.
Posted on Mar 27, 2008
How can i repair amp
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
May 10, 2014 | Kenwood Audio-video Stereo Receiver Kr...
Loud stereo noise comes though the speakers regardless of volume level
RAP, delete all RAP , crapp
cured.
id pull fuse to radio and radio amp
be ready to loose radio codes. (RTM) on that first.
Feb 21, 2014 | 2009 Toyota Corolla
Radio on but no sound after installing after market subs
to create a spark you must have had power connected somewhere. Did you have your radio turned on when you connected? if yes you may have blown the amp in the radio. If no then you have other issues with wiring and possible damage.
It's one of those instances where I'd need to be there to diagnose it.
Start by double checking the stereo is working, check its wiring is correct try each speaker connection in turn. If the stereo works and all the outputs work then double check the amps wiring and try a normal speaker connected to it. You must get the picture by now, you need to identify the source of the fault. to help you better I'd need a wiring diagram.
Dec 20, 2011 | 2003 Toyota Camry
My speakers just out of the blue began to buzz in the middle of a song. The volume was low & did not seem to effect the buzzing - after I turned music off speakers began to make a high pitched ringing...
I've never worked on this model so I can't give you a definite part value or location, but you'll probably find a bad filter capacitor (or possibly more than one) in the power supply. The power supply converts the AC power line voltage to the DC (direct current) needed by the electronics. If the filter capcitors don't work, the result isn't smooth and steady, and the result is an annoying hum. You're probably hearing this.
It's possible to replace the bad capacitors, but it's not always easy. The people who make computer speakers don't often design them to be serviced, and sometimes it's a challenge getting into the power supply. But if you or someone you know with some electronic soldering skills is willing to give it a try, you might be able to bring these speakers back to normal. Good luck and thanks for using Fixya!
Jun 01, 2011 | Dell Ay410
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
Bose radio comes on but no sound in my 2004 chevy avalanche.Sometimes even with radio off you hear a popping sound come from speakers. thanks
First Visually check all your fuses. Does rig have amp for stereo by any chance? It sounds like amp is bad and/or fuse is blown. Amp is wired between radio and speakers, and a shorted amp would make crackling in speakers when radio is OFF
Feb 26, 2011 | 2004 Chevrolet Avalanche
Technics su g70 amp problem also?
it doesn't sound like it. but maybe. it would be the input section of your amp that blew if it did go. try replacing your speaker wire first, if that doesn't work then your volume knob(if the volume is analogue) may need to be replaced. if that doesn't work. then you may have blown the amp. what source are you testing with?(cdplayer, dvd player, etc.) and what inputs are you using? (analogue, digital optical, digital coax)
Aug 11, 2008 | Audio Players & Recorders
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Sharp CD-XP5500 CD Shelf System Logo
91 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Gary
Gary
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
