Question about Ovens
Light does not work on GE microwave in the GE oven/microwave combo
The light does not work in the microwave of a built in GE oven/microwave combo, model JKP68GOKBG. I replaced the bulb but still no light. The microwave works fine. I got the circuit diagram from GE and it shows a light relay. Is it the next thing to troubleshoot? How do I do that? Other ideas? Is it possible the door switch (which opens the light) is bad? Note that microwave works with door closed as usual, only problem is it is dark inside!
Thanks for your help.
  • 770 Answers
SOURCE: jenn-air microwave light bulb
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Posted on Jan 26, 2008
  • 2651 Answers
SOURCE: Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Posted on Mar 09, 2008
  • 770 Answers
SOURCE: Oven light bulb
Check your email
Posted on Jun 15, 2008
SOURCE: Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Posted on Nov 18, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Lower oven will not heat, circuit fuse is OK
You will have to remove the unit, to access the back and pull the covers, most likely you coil is burned out. Or a safety fuse to the coil is tripped last but not least, your control card is burned out. Might want to give make and model
Nov 11, 2015 | GE Jkp90Dpww 27" Built-In Combo Microwave...
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Kitchenaid selectra
possible but unlikely. they are physically connected?
Mar 07, 2014 | Ovens
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
Microwave has no power. It is a combo oven/microwave built-in oven and the microwave has no display or power to the interior light. Is there a fuse location or a way to re-set the oven?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 27, 2010 | Ovens
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
GE jkp85 Microwave oven appears to be working
Most likely related to magnetron and diode this is for qualified tech to do only.
Nov 13, 2009 | GE JKP86 Electric Double Oven
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
