Question about Sanyo DVW-5000 DVD Player/VCR
DVD Eject tray stuck
The disk tray won't open. There is no disk stuck in there. When I press the eject button, the words "load disk" light up and I can hear the tray trying to eject, but it never does. Then it will say "no disk" after a few seconds and not do anything else.
  • 1 more comment
  • Lynne Moody Jan 03, 2007
    Thanks for your reply.
    A few minutes after I posted that, it opened!
  • Anonymous Nov 21, 2007
    I have an Ilo DVD player and the tray will not open.
    It tries when I push the open button but no luck.
    Is there hope.
    Thanks
    Dave
  • jerry4208 Jan 05, 2008
    Same problem, tray stuck won't open. Call Sanyo and was told to unplug the unit for one hour to reset the unit, plug it back in and try to open the tray again and if that did not work to get a new unit. "Resetting" the unit did not work.
Your problem is more than likely mechanical. There is a belt that makes connection between the motor and the loading mechanism. Take the unit apart. Remove the belt it is probably in the front. Clean the belt and pullies with denatured alcohol. reassemble. The best solution is to replace the belt but this may get you working till you get one. Belt sources http://www.mcmelectronics.com/
please visit my eBay webpage
http://members.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=wilcox1976
Posted on May 15, 2008
    New Friend:
  • 12 Answers
Honestly, there is not much hope on this one. I read your posting and did not want to ignore it. Is this a new unit, recently purchased? If it is, try returning it to the local store for a refund or exchange. Most stores have a 14 day return or exchange policy on their electronic equipment. Please review the back of your receipt to find out the window for returns. If it has been more than 14 days and you are within 1 year of the purchase, you can contact the manufacturer to have the unit repaired under warranty. The tray is composed of rounded geared teeth devices that come in contact with each other to open and close the tray. These are held together by an elastic band, if this band is out of place then that would make sense if your device fails to open or close. This unit needs to be repaired by a professional as new parts are required... Best of Luck!
Posted on Jan 03, 2007
I've had the same problem for some time. I have found that if you insert a VHS tape on the cassette side, insert then eject, and then switch back to the DVD player the DVD door usually opens right away. Not sure what if any corrolation there is between the two sides of the player but it's worked for me.
Cheers...Tom from South Central Wisconsin
Posted on Nov 29, 2007
Optical drive tray is open, can't close - disk is stuck inside my notebook
Power it down and if you look very carefully, near the eject button is a hole.Insert a straightened paper clip and the drawer will open. Unless it is a Mac.
Nov 09, 2013 | Computers & Internet
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Will not eject disk.
Almost always, your described problem could be caused by:
  • stuck disc;
  • fault in the load/eject mechanism.
It it were a stuck disc, the correct fix would be to open the unit and manually extract the erring disc. However, there may be possible workarounds:
  • unplug the unit for an hour or so;
  • press and hold the eject button while plugging in; or
  • invert the unit (bottom side up);
  • plug back the Apex and quickly unplug soon as you hear the mechanical noise start;
  • revert to normal position and try ejecting; or
  • while still in the inverted position, press and hold the eject button while plugging in but must unplug quickly even before the tray starts to move out.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2010 | Apex Digital AD-1225 DVD Player
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
A disk is stuck in the tray of my sony DVP-NS305 player. The disk tray will not respond to either the hand piece or the button on the player itself. The word "Locked" comes up on the display. How...
Unplug power cord, and whenb you plug power back and restart the DVD, keep pressing repeatedly the eject button on the unit.
Do this a couple of times.
If it does not work you will need to take apart the unit to take out the disk. In this case consider calling a qualified technician if you are not sure about how to do it.
Oct 04, 2008 | Televison & Video
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Sanyo DVW-5000 DVD Player/VCR Logo
534 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
