Question about BenQ SP820 Projector
Doesn't stay on
I have a BenQ SP820 Digital Projector. I have it connected using a VGA cable to my desktop computer. It is connected to a Nvidia GeForce 8600GT 512MB GDDR3 video card as a second monitor.
It turns on fine, the loading screen comes on. I can see my desktop on it for a short time and then it shuts off. When it shuts off the fans seem to go into turbo mode and it won't shut off unless you hit the power switch on the back. I read the manual and noticed i am getting an LED error code of:
Power light=6
ready light=4
That code is Fan4 error (Power), according to the manual.
I just purchased this unit like 4 hours ago. It was an unopened box and all pieces were accounted for.
Please do what you can to help me out.
Thanks,
Mat
4 Suggested Answers
SOURCE: LCD shutting off automatically
Had the same problem with PB2140, during startup the lamp went off and power and lamp leds turned on. This happened after the projector fell down. I read a post there hat mentioned it was probably the power supply so i disassembled the projector. I found out that a small transistor of the power supply was torn away but it was still inside the projector. I found it, put it back and the projector works just fine. Thanks!
Posted on Oct 29, 2008
Basti
  • 1447 Answers
SOURCE: projector shut down
Hi
Replace the lamp, or better yet try removing and reinstalling the lamp.;
Hope this helps
Posted on Nov 01, 2008
ginko
  • 19396 Answers
SOURCE: SP820 lamp never comes on. It
Hi.
18 blinks is not a fault code. The LED probably starts blinking because the controller board is faulty, and stops after 18 times because it dies always at the same time. Problem is likely main controller board, you can try testing the board at component level. Check connectors a shorted connector is a common fault that may have unforeseen effects. Test PSU voltages just in case, wrong voltage to controller may fry it and may result in no error code.
Posted on May 16, 2011
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
How can I connect BENQ MP510 multimedia projector with Acer Aspire one D255E notebook using windows 7? Do I need installation of extra driver for that?
Hi!
No you don't need a driver, connect it using a VGA Cable, then press FN Key at the same time with Fkeys that has a monitor screen Icon on your keyboard.
Hope this helps.
Mar 17, 2011 | BenQ MP510 DLP Projector
I have a Dell 2300MP projector which works perfectly in cloned monitor mode with a 3-year-old desktop computer running Windows XP with an ATI card. I have very recently bought a new desktop running under...
Hello
This problem was also faced by me some time ago, i just change the data cable (vga cable) and then it will recognized by system,
i suggest to change the vga cable and try to find the DVI cable if possible to connect the projector to system end.
Hope this helps.
Jan 25, 2011 | Dell 2300MP Multimedia Projector
How do I connect my Benq-mp610 projector (without HDMI) to my ps3
hi,
u can convert the vga input of ur projector to component video input, and u can connect ur ps3's component video to the projector. component video to vga convection cables are available.
ok
Dec 27, 2010 | BenQ MP610 Multimedia Projector
Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Jun 02, 2010 | BenQ MP721 DLP Projector
Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
Aug 18, 2009 | Dell 2400MP DLP Projector
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
BenQ PB6100 Component input problem
You can get high defintion by connecting a cable that is component video source on one end your (dvd) and VGA (to projector)on the other. This cable is available from cables to go.
Aug 24, 2007 | BenQ PB6100 Multimedia Projector
BenQ SP820 Projector Logo
73 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
