Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg wm2233hw front load washer is vibrating
We have leveled it checked pedstals and it also has no shipping bolts what else can we do to correct vibration?
t00nz
  • 4738 Answers
SOURCE: I have a LG WM2032HW Front Load washer that shakes
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as shown here. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Nov 08, 2009
SOURCE: Vibration
Vibration problem fixed!!  If your washer vibrates excessively, check to be absolutely sure that whoever insalled it removed the drum locking bolts (4 big bolts on back of machine).  My store installer didn't ,and the machine danced across the room.  Second appliance repair fella (he was here for something else) removed the bolts, and voila - problem solved.  Problem is he says in the three times I used it before the bolts were removed, I may have done irreparable damage (imagine the resistance with the washer trying to spin while bolts have locked it down to prevent this action).  So I'll go back for a replacement, but in the meantime, it works and vibration is entirely reasonable, and my machine is on a crappy wood floor (not concrete).
Posted on Oct 26, 2007
  • 1294 Answers
SOURCE: Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Posted on Jan 12, 2008
  • 14 Answers
SOURCE: New LG WM2688H*M Steam Washer
Your load is unbalanced, at least that is what is sounds like. Have you taken out all the shipping bolts?
These washers and dryers hold very little clothing, 3-4 pair of jeans or less if the person is really large and maybe three regular sized thick bath towels since they weight so much when wet. You must make sure you are not overloading your machines when in use.
Good luck and if you keep having problems I would take a look at the manual and call customer service to report this issue to them. Make sure you get a repair number for your records.
Posted on Jan 14, 2008
rickzilla
  • 706 Answers
SOURCE: LG WM2233HW washer plumbing rattle.
Hello Justin,
What you are hearing is what they refer to as "Water Hammer'.. and aside from the noise.. it probably won't do much damage however home improvement stores such as Home Deot and Lowes sell add on devices that are installed onto your supply lines to absorb the shock when water is cycled on and off... You'll need to tell them exactly what size pipe you have and ( depending on how familiar you are with plumbing) you may want to hire a plumber to install.. They may have a water hammer add on that fits onto the screw on water lines.. Hope this helps..
Posted on Sep 21, 2008
Bad vibration when washer is spinning.
If the washer is vibrating, it's not sitting solidly on the floor. Move it until it sits solidly. If needed, adjust the leveling legs. It might also vibrate if the shipping blocks and bolts weren't removed when the washer was installed, or the wash load isn't distributed evenly.
If all this looks good, check the shock absorber to see if one has broken.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Can I get an on line manual for model # WM-2233HW LG front load washer
Yes, LG has the user's manual for the WM-2233HW on the product site. Click on the Support tab here: http://www.lg.com/us/appliances/washers/LG-WM2233HW.jsp . The link to the manual is on the right side of the page. The manual is in a pdf so you will need Adobe Reader or a similar program to read the file. The direct link appears to be http://www.lg.com/common/product/support.jsp?localeCd=US&productId=WM2233HW&uri=/us/appliances/washers/LG-WM2233HW.jsp&categoryIdCms=2# . If this link doesn't work, please start at the first link I provided.
I hope this helps.
Oct 02, 2011 | LG WM-2277HW Front Load Washer
Washer vibrates and walks during spin cycle. Washer is on a vinyl floor
check to make sure the washer is level, and double check to make sure the shipping bolts have been removed from the back of the washer.
Feb 12, 2011 | Maytag MAH8700A Front Load Washer
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
WE recently purchased a front loading Frigidaire washer. I love it except we can't seem to get it level so it doesn't vibrate. It is on a concrete floor and thought the feet were self leveling but that's...
Make sure you have removed all the shipping bolts and straps. Front loaders come with bolts that go thru the back to keep the drum from moving during shipping. If you brought the washer home yourselves you may have left in these shipping bolts. Refer to you installation manual. It will give detailed instructions on how to set up your washer. If bolts are left in place the washer will vibrate and shake excessively and cause major damage if left in for too long.
Feb 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Moved washer from Cal to Missouri, since I got here it vibrates the whole house when its on the spin cycle, washer is level
I think you have a weak floor. Place a clear glass of water on the floor about 2 feet from the machine and watch it iwhae it vibrates. Also, you didn't say whether you re-installed the shipping bolts when you moved it. If not, you could have a bent drum(spider) shaft.
Jan 08, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Excessive vibration Machine is level
Also, make sure that you removed the shipping bolts from the back of the machine. Many people forget to remove these when first set up. And finally, if you're certain that the machine is level, with all four feet firmly planted, then consider dampening the sides of the machine with foam. It's a very simple fix, but effective for those "tuning fork" vibrating machines. See this link.
Dec 11, 2009 | LG WM-2277HW Front Load Washer
My LG WM2233HW vibrates and crawls forward during the spin cycle, it is not on a pedestal, does anyone nkow if the pedestal will stop this?
Not sure what pedestal you refer to ,but vibration and movement is often caused by machine not being level / not stable initially . With machine off ,hold the top firmly and see if you can rock it in any direction , if you can , put some packing under the base to stop this , then operate machine , it should be better.
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Jan 12, 2008 | LG WM2277H Front Load Washer
Vibrates and walks
most of the time with this problem they have not removed the shipping bolts get your owners manuel refer to the installation instructions under remove shipping bolts before operating look and see if they removed them i think they are marked in yellow if not call them and tell them to come do their job and pull the bolts that is a good washer and make sure they level it let me know please
Jan 01, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
189 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
