Question about Logitech Cordless Click! Mouse
Gulbeyaz_hellokitty@hotmail.com i want the opposite of movement
    Problem Solver:
  • 8 Answers
This is directly from Logitech:http://logitech-en-emea.custhelp.com/
"Logitech MouseWare Software:
1. Right click on the Logitech white mouse icon in the System Tray and select "Mouse Properties".
2. Click on the "Buttons" tab and your pointing device should be shown. If you have more that one mouse connected, select the mouse you wish to program by clicking on the "Devices" tab, and select the mouse you wish to program from the drop down menu, then go back to the "Buttons" tab.
3. Scroll down the list of buttons and select the button you wish to program, and click on the function to highlight it.
4. Now click on the "Modify" button. A "Modify Button Function" box will appear with a drop down menu. Select the button assignment you wish to use and click the "OK" button. Now click the "Apply" button to save your changes.
Using the "Keystroke" button assignment.
If the button assignment or keyboard command you want is not listed under the button assignments, you may want to use the "Keystroke" button assignment. Using the MouseWare steps above select Keystroke under Step 3. The "Keystroke Assignment" box appears. Click your mouse cursor into the box that states "Unassigned". Now press the key or combination of keys you wish to use and click the "OK" button. The function should now be displayed in the current list of button assignments. Click the "Apply" button then the "OK" button."
Hopefully this will help. Please let me know if it doesn't.
Posted on Nov 25, 2008
How do I fix the electric rear view mirror
Most are not fixable...listen to hear if you hear any movement in the mirror you are working on...if you hear movement but it is not moving then the assembly needs replaced... if you dont have movement check to see if cycling the switch to opposite mirror engages opposite side....if the other moves the one you are working on doesn't then it is the moter in the mirror or a bad switch
Feb 20, 2016 | 1997 Dodge Ram 1500 Club Cab
Juki ams 220b dose not go back to origin the same on x scale while you are sewing
Hello Raymond
for that problem , please check X movement sensor( left limitation and right limitation ) if any X sensor damaged machine will not move at correct movement. one more thing , also if X movement not adjusted correctly it will make same problem.
- adjust so that the X right travel limit sensor and X left travel limit sensor respectively actuate when the feed mechanism moves 153 cm to the right and left from the origin by two screws for X sensor base.
thanks and best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Mar 25, 2015 | Juki Sewing Machines
Pen cursor moves in opposite direction than its suppose to
Use your pad in the other direction or invert the cursor movement in mouse settings......
Dec 26, 2013 | Monoprice 8x6 inches graphic drawing...
Are you suppose to be able to move the tub around when you open the door?
Front load washing machine? If it is it depends on what you mean by move the tub around, if it is just spinning then they do this as the drums do not lock when stopped, if you mean there is excess movement on the inner drum then you can check this by holding your hands at opposite sides of the drums just inside the door opening, locate the outer drum at the rear of the door seal and press your fingers against it and with the other hand press the inner drum in the opposite direction. If movement is felt between the 2 drums when pressed in opposite directions then the drum bearings may have failed or the spider shaft may have broken.
Dec 31, 2012 | Washing Machines
Whilpool duet
If the bearings are gone te easiest way to check is to press your fingers on 1 hand on the outer drum and with the other hand press the inner drum in the opposite direction. If there is any movement between the 2 drums then the bearings have failed and need replacing. There should be no movement in the drums when pressed in opposite directions.
Dec 27, 2012 | Washing Machines
Can not download. nothing happens
did you check your internet connection? are you on a network? add me at facebook so i can help you more further. reynette@hellokitty.com
Feb 12, 2011 | Computers & Internet
How do I unlock the memory card Kenneth Grace the graces24@hotmail.com
There is a small switch on the right side of the card (grey knob). Switch it to the opposite position and you're good to go.
May 06, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
LpgiTech Cordless Click opposite movement
Yep - just turn it around so you hold it correctly in your hand :-)
Feb 26, 2008 | Logitech Cordless Click! Mouse
Logitech Cordless Click! Mouse Logo
251 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
