Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a Magnavox 51MP6100D/37 tv that doesn't have a manual,
The tv just shows weak signal across the screen and says time not available and missing rating. We can't get the menu set up or anything to work. The only thing you can use it for is a screen.can you help us with the problem
Http://www.retrevo.com/support/Philips-51MP6100D%2F37B-TVs-manual/id/278dj091/t/2/
Posted on Jan 18, 2009
Have problem with many channels while a converter box is fine
Ur tv problems it is the tv antena signal problems.Tries websites like Amazon.com,Ebay.com or Walmart stores to buy a Digital design antena and used it will have no more problems with weak signal or no signal for tv broadcasting channels.
Jun 23, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Ihave a 52" Magnavox rear projection TV. Model no.
You need a convergence kit available at tvrepairkits.com
Jan 04, 2011 | Philips Televison & Video
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 51mp6100d/37 power light flashes and
you can get replacement boards from www.tvrepairworld.com you can call or send them a email they respond quickly.
Apr 15, 2010 | Televison & Video
Missing or weak signal
try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not work.you may try taking the
tv to a friends house and see if the tv works better.
Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
223 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
