My bass guitar amp is blowing fuses
The amp is blowing fuses it has a 2.5 amp 250 volt fuse and it blows everytime you turn the power on it it blows instantly i dont know what to do
  • Anonymous Jan 28, 2009
    I have the same problem with my Yorkville 200B Bass amp. Can anyone offer suggestions?
  • MrMach5 Mar 31, 2009
    I have the same problem with my Yorkville 100B Bass Amp
  • 4,234 Answers
This sounds like the main rectifier diode/bridge is shorted. If you can rpovide the make and model, I may be able to give you more details.
Thanks,
Dan
Posted on Nov 25, 2008
    Problem Solver:
  • 16 Answers
Hi ! I have a soluution and it is about to be published on http://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
Please check in a few days time
Posted on Dec 04, 2008
On the small Fender 15G/15R amps, if the power amplifier IC is bad it will immediately blow the fuse when powered. To check the the IC you have to remove it from the chassis and measure the resistance between two of its three legs. You need to find a schematic for your amp online and measure at the test points with a meter as a starting point.
Posted on Feb 06, 2009
Blowing 50 amp fuse under hood in 2002 crown vic
To blow a fifty amp fuse would take a major short circuit, referred to as a 'dead short' this means that a wire with 12 volts positive (+) is in direct contact with an Earth (-). If you follow the path of the power you will find where this is happening. sometimes you may need to temporarily disconnect some contacts
Jan 31, 2014 | Ford Crown Victoria Cars & Trucks
Amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Dec 31, 2013 | Car Audio & Video
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Marshall 8080 valvestate amplifier
There could be a short in the rectifier diodes or in the transformer itself. Can you take some measurements inside the unit?
Let me know.
Dan
May 29, 2008 | Audio Players & Recorders
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Ashdown Perfect 10 Bass Combo keep blowng 2 man fuses
What main fuses? Fuses in the car electrical system? If so, your amp is too powerful to run through the cars electrical system, you should get a heavy guage wore ran straight from the battery, with its own dedicated fuse placed in-line, ad close to the battery as possible. Wait, is this a bass guitar combo??? Open it up, if there's wax coming from the power supply, thats prolly the culprit. Check for any obviously blown resistors or any short circuits. But most likely, its not gonna be user-servicable.
Feb 28, 2008 | Ashdown Perfect 10 Bass Combo Amp Car...
2,111 people viewed this question
 Grubhead
Grubhead
