Question about Whirlpool RF378 Electric Kitchen Range
Oven Range Door Does Not Lock
I have a Whirlpool Accu Bake glass top range/oven. I have been trying to clean my oven. I push on the oven clean button and the door does not lock so that the cleaning can begin. What do I do? Thank you.
  • 2 more comments
  • James Large Jan 09, 2007
    On this model you do not have to set a time. You push the button the door latch locks and the time begins.
  • Anonymous Nov 20, 2007
    I pushed the clean button and it did nothing. Now any button pushed it displayes off.
  • Anonymous Nov 24, 2007
    I stopped the cleaning before it could finish and the door is locked, how do I unlock it?
  • kcdave Apr 14, 2008
    When I go to start the self clean cycle the door will not lock and after 60s I get a P1-F5 error. I'm suspecting the lock solenoid or the relay is not working. Are these componets located under the cook top what is the best way to access them?
    Scholar:
  • 76 Answers
Jocalo, Did you set up the time for cleaning and pushed the "start" button? Gendos
Posted on Jan 07, 2007
  • Gennadiy Kagan Jan 09, 2007
    Following you will find the insruction for self clean from the "Use and care manual" for your oven:
    "Press AUTO CLEAN.
    The clean indicator light will light up.
    This will automatically set a 31⁄2-hour
    Self-Cleaning cycle.
    NOTE: There will be a 30-minute cool-down
    1⁄2 hour before the cycle is over.
    2. Set the cleaning time (optional).
    If you want a Self-Cleaning cycle longer or
    shorter than 31⁄2 hours, use the hour and minute
    pads to set the cleaning time you want. Press
    the ?up? (s) or ?down? (t) pad(s) until a time between
    21⁄2-41⁄2 hours shows on the display.
    ?Use 21⁄2 hours for light soil.
    ?Use 31⁄2-41⁄2 hours for average to heavy soil.
    3. Start the oven.
    The on and heat indicator lights will light up.
    NOTES:
    ? Make sure the door is closed all the way. If the
    door is open even a little, it will not lock. If the
    door is closed, it will lock after you press
    START/ENTER.
    ? Do not attempt to open the oven door while
    locking.
    4. After the Self-Cleaning cycle starts:
    The door locked indicator light will light up when
    the oven door locks.
    5. After the Self-Cleaning cycle ends and the oven
    reaches normal baking/roasting temperatures:
    The clean, door locked, and on indicator lights
    will go out and the door unlocks.
    Press OFF/CANCEL to clear the display.
    6. After the oven cools to room temperature, wipe
    off any residue or ash with a damp cloth or
    sponge.
    If needed, touch up spots with a mildly abrasive
    cleanser or cleaning sponge."
    Good luck.
    Gendos....post back
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Can't find my operator manual. want to self clean oven. Whirlpool model RF262LXST
i have a whirlpool gobal accu bake system with microwave on top oven on bottom model number gmc 275pd56 serial number xp1006922 but went to whirl pool site to get manual cant find it but the oven works fine the microwave everything total works but dont warm noithing help please
Jan 31, 2011 | Whirlpool RF265LXT Range
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool accu bake oven door locked after self cleaning
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^YRG
Apr 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Whirlpool RF378 Electric Kitchen Range Logo
176 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
