I just bought a new computer with windows vista and the drivers for my HP Officejet K60 loaded but I get an error that no printer is connected when in fact it is. When I go to control panel then printers, the printer icon is there but it says error instead of ready.
-   I just inherited a K60 printer and was planning to buy a Mini-C/Micro C Adapter so I can connect to the USB port on a laptop with Vista Home Premium operating system. Do you think that I might end up with the same problem?
Did you download the latest driver from HP website for Vista operating system? -   pbroudy
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink....
(More)
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink. How can I select "print in black only?"
