Question about Motorola Mobility W510 Mobile Phone
Number that isn't voicemail is labeled voicemail
Phone: motorola w510
One specific phone number always shows up as voicemail, regardless of the name of the contact with which it is associated.  This number is definitely not my voicemail.  SIM card has no contacts, all contacts are in the phone.  I've tried renaming the contact, deleting the contact and all references to the number - but whenever I dial that number the phone references it as "voicemail".I have a couples plan, and the number that this occurs with is, annoyingly, the other number associated with the plan.  The other person does not have the same issue.
Please help?
    Brigadier General:
  • 7,752 Answers
It would be best to try a master reset of the phone then try again or contact your mobile provider for further assistance...
Posted on Dec 27, 2008
Subsity code for motorola W510
You can get the subsidy code for your Motorola W510 from your service provider or from reliable online sites like onlinegsmunlock.com .Specify your phone's manufacture, model,country and network to get the codes. The steps to unlock is simple here and the codes are reasonably priced!!!
May 29, 2012 | Motorola Mobility W510
How can i pass music from my computer to my new motorola w510
There are several ways you can send music from your computer to your new phone.
You could use your phone cable, or a memory card reader, or transferring via bluetooth, or using a pC suite. It all depends on which method you find convenient to use.
Take care.
Dec 28, 2009 | Motorola Mobility W510 Mobile Phone
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Thanks
S
Nov 21, 2009 | Motorola Mobility W510 Mobile Phone
Need subsidy code
You can get the Motorola W510 Subsidy code from Classicunlocking.com .Here they provide the code with free instruction to unlock from tmobile..To get the code you have to fill the Country ,network name and IMEI number..
May 28, 2009 | Motorola Mobility W510 Mobile Phone
Motorola w510 will not turn on i need numbers and pics off the pn
Hey try to connect the phone to the USB cable that came with it & your computer. Make sure that it is completely charged in any case first though you may have forgot to charge it.
Jan 27, 2009 | Motorola Mobility W510 Mobile Phone
Problem with motorola w510
Try turning off your phone and take out the battery for a minute. Turn it back on and try calling yourself from another phone. It should show you the person who's calling or incoming call.
Oct 20, 2008 | Motorola Mobility W510 Mobile Phone
Transfer phone numbers
sorry it would be best to have the phone repair or the mainboard place into another w510 and then transfer the contacts to the simcard.
Sep 16, 2008 | Motorola Mobility W510 Mobile Phone
Motorola raza v3
I'd check to see what the phone thinks your voicemail number is. Go to your message menu then press the softkey for 'Options', then 'Voicemail Setup' and see what phone number it has listed.
Jan 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W510  Mobile Phone Logo
100 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
