Question about Sharp AL-1540CS All-In-One Laser Printer
Shows offline My sharp printer appears offline on my computer and does not print the documents. thnx
how whee
  • 8 Answers
SOURCE: D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Posted on Feb 21, 2008
oldnovii
  • 667 Answers
SOURCE: Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 09, 2008
rylee_smith
  • 8619 Answers
SOURCE: printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Posted on Jan 03, 2009
  • 86 Answers
SOURCE: Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Posted on Jan 10, 2009
  • 50 Answers
SOURCE: status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Posted on Mar 24, 2009
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
How to fix printer saying "offline" on some workstations, but it is really online?
You need to make an adjustment in the port settings on the problem computers. Take a look at my instructions here.
Sharp Printer Offline Solution
Sep 09, 2014 | Sharp MX-3501N All-In-One Printer
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
Mar 28, 2013 | Canon Black Pixma Mp 280 High Quality...
How do i get my printer from offline mode back to online mode
  • Make sure that the printer is powered on.
  • Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
  • Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
  • After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
  • Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
Help m fix my printer. I don't have enough knowledge to do it alone. I have been plugging all the wires that connect the printer and computer but yet there's still a warning that pops up and says...
ssue: ERROR: Printer is offline.
Solution: Set printer from Offline to Online
Set Printer Online If the printer is set Offline, an error message will appear and the print job will not complete. printeroffline.gif
  1. Open Printers folder:
    Windows 7 users: click here.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Right-click your printer's icon and select 'Use Printer Online'. The document will print.
  3. If the document does not print and the job remains queued, a printer icon will appear to the left of the time on the Windows taskbar.
  4. Double-click on the printer icon to open the 'Printer' window.
  5. Click on the document title below the 'Document Name' column.
  6. From the 'Document' menu select 'Restart'.
1. Click the start icon, then click Devices and Printers.
2. Right-Click the printers icon and select See what's printing in the dropdown menu.
3. In the next screen click the printer tab. Use Printer Offline will have a check mark to the left of it. Click Use Printer Offline.
4. Close the window. The printer will now be used online.
Sep 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Printer will not print
First of all basics:
1. Make sure printer is switched on and connected to computer.
2. Go to Control Panel and then Printers and Faxes. Double click the icon for your printer. When box appears click on Printer then make sure that "Use printer offline" is not checked. If it is, left click to uncheck this option.
3. If there is a queue of documents waiting to be printed then again click on Printer and click on Cancel all documents. This should clear the backlog. Restart the computer and follow step 3 again to make sure the print queue is empty before attempting to print anything.
Jun 10, 2009 | HP Photosmart D7460 Printer
Sharp AL-1540CS All-In-One Laser Printer Logo
166 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
