Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Remove the top to an ultimate care washer
Is the only way to remove it from the bolts?
    President:
  • Whirlpool Master
  • 2,651 Answers
If you look over the top of the console, straight down in either corner youll see 2 screws(phillips), removet these screws adn the control panel will tilt back and then release the 2 brass clips and the entire cabinet will tip forward allowing you acess to anything you need, you tube has videis on how to remove and reinstall the cabinet as well as how to replace mostparts,defintiely a good site get inifo form
Posted on Nov 25, 2008
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you remove the agitator from the Maytag Ultimate Care II washing machine?
Pull out the softener cup. Remove the water seal by pulling on the two wings. Remove the retaining bolt with an 11mm socket and a couple extentions. Pull the entire agitator out of the machine. With a sharp pointed tool cut the four melted portions of the white plastic **** even with the top of the clear plastic ratchet assembly by inserting your tool thru one of the three holes in the side of the top agitator. Pull the top agitator from the bottom agitator.
Sep 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you switch the agitator switch in a whirlpool washer
okay take the top of the agitator off by pushing it or by pulling it. Then remove the plastic rubber seal. Then use a rachet set to remove bolt.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I need to remove the agitator due to something being spun around it and it will not spin; How do I remove it?
Pop the fabric softner dispenser off the top of the agitator, pull the round plastic piece in the agitator out, the you will see a bolt through the center, remove the bolt and the agitator will slide out
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II washer that had developed a "wrap" sound coming from the agitator. The agitator had a loose fit at the top, and can be moved about a 1/4 inch from side to side. How do I...
Remove the fabric softner cup. Remove cover underneath it by pulling up on it. It just snaps in and has a seal on it. Remove the bolt and lift up the upper agitator. You will need to get an agitator repair kit from an appliance parts store. It has seals for bolt and cap,.thrust washer for the botttom of upper agitator , cam dogs and a new holder and plate. Be sure to take the model number with you.
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Corroded lip
Need to know what you are referring to as the top. Do you mean the lid or the chassis top.
The actual top section is bolted from the inside.
Dec 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal De
