Question about Freeplay Energy BayGen AM/FM/SW Radio
Dynamo problem The radio works fine when it is powered by the solar panel. When I wind it and turn the radio on I get nothing. I have noticed after I crank it the crank unwinds slowly, then when I turn the radio on it unwinds a little faster like power is being used but I get no sound out of it. I have taken the back off but I don,t see any wires lose. Thanks in advance for any help.
In the original big black Baygen radio there is a blue wire with a solder joint that breaks. This wire shunts part of the load back to the generator and prevents it from running to fast and going over-voltage. I am guessing that a similar problem is affecting your newer smaller radio. On the original radio after you take the two halves of the case apart there is a blue wire that comes from the 3v input jack on the back half of the case and goes to the radio circuit board near the top corner. The solder joint where the wire is soldered breaks easily. With this wire broken the generator will run to fast because there is very little load. The radio will still play if you slow the generator with your hand as it is playing back. If you resolder this wire the radio will work and the generator will run at the proper speed. This takes only a moment or two.
Good luck.
Posted on Nov 13, 2008
If you have the ac to dc adaptor, try insterting the plug (without plugging in the wall). This somehow allows the windup to work on mine, otherwise, similar symptoms as you...
Posted on Jan 17, 2007
Sometimes the belt stretches out from heat or hours of use, and you can put a small rubber band over the pulley and then place the belt back on over the rubber band to make it work like it should. This gives the belt a surface to grab to turn the pulleys.
Posted on Aug 19, 2012
Inside the BayGen radio there is a small motor/generator installed inside the spring drive mechanism. The motor's pulley however protrudes outside of the spring drive mechanism. In my case the small diameter black rubber drive belt had simply fallen off inside the case. This drive belt extends from the small metal generator pulley to the large white pulley. It requires gently bending the large thin white cog which basically almost touches the large pulley to get the drive belt to reach the motor/generator pulley. Once the belt was reinstalled the radio in my case worked OK, with a bit of lube on the cogs and a little arm power on the spring winder in the correct direction, to get it started.
Posted on Jul 20, 2010
  • Canadado Jul 20, 2010
    I would also like to point out that UNDER NO CIRCUMSTANCES SHOULD ANYONE TRY TO OPEN THE CLEAR PLASTIC SPRING DRIVE CASE, AS ACCORDING TO THE MANUFACTURER THERE IS ENOUGH TENSION IN THE SPRING TO CAUSE SERIOUS INJURY OR EVEN DEATH.
SOURCE:
Whats the best renewable energy source?
Solar power is the best renewable energy source For more details click here- Solar Panel Manufacturer in India
Jan 04, 2017 | Green Living
KA500 ip will not charge iPhone 5
The BEST Great watch.Easy to work around bezel concerns Great watch,easy to use.The production GARMIN forerunner running watch fitness is HOT THE Garmin Forerunner Heart Rate MonitorYou can view and order THE BEST products at this.
Dec 12, 2012 | Kaito Voyager KA500IP Solar/Dynamo...
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
HOT LEAD FROM SOLAR PANEL HAS A ELECTRICAL COMPONENT WHICH IS BROKE. WHAT IS IT? (6-V)
Either a voltage limiter (because a solar panel can put out upto 21 volts.... BUT more likely a diode - which prevents the storage batteries from discharging through the solar panels (power goes only INTO the batteries when the diode is working.
Radio Shack will be able to match it if you remove it and take it to them.
Jan 21, 2010 | Parmak Solar Fence Charger
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
Wind turbine plans/solar panel plans
You are in for a lot of fun and money saving tips and instruction. I as you am interested in building a wind turbine/ generator to do my part in saving the environment and saving me money. I have a small work -shop and have some generator parts to work with. Reading about building is fun but watching a video of actual working machines is the most. Go to www.youtube.com and enter homemade wind generator in the search box and enjoy the fun and instruction. Good luck with you project.
Jan 30, 2009 | Electrical Supplies
No more self powerd source
I assume that the rechargeable batteries have expired. The trouble is that the batteries are hard-wired into the radio itself. Unscrewing the back and carefully replacing these with similar-rated cells would be possible but difficult. A poor design, which happened to mine too.
Jan 31, 2007 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Freeplay Energy BayGen AM/FM/SW Radio Logo
856 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
