Question about Dell XPS M1210 Notebook
Xps m1210 is dead and no power even with a new ac adapter
I had ac adapter problem and i bougth a new one but the xps m1210 didn´t charge or power again, adapter looks fine. A technician told me that the motherboard protects itself when it detects adapter problems and have to disassembly the laptop in order to get access to the motherboard and unprotect it. some one knows how to do it?. Thanks
  • Anonymous Nov 25, 2008
    I have the same problem anybody successfuly fixed their's? Thanks
  • Guerre Schuler Mar 20, 2009
    Mines dead too, sctochamara link is also dead. Dell forum says to remove the Memory,HDD,optical drive,and battery.Once this is done hold
    down the power button and the fn key for 10 seconds,if you see the
    LED's across top of laptop,CAPS, NUM,etc..(exception of the Bluetooth
    LED) lit solid green,then yes the MOBO needs to be replaced. It also says if the lights flash at least the MOBO is bad. Pretty $2K brick
The M1210 suffers from the same die packaging problem with its Nvidia GeForce Go7400 chip as many dell laptops do. However dell does not admit this, and has only extended the warranties for recently manufactured laptops.
To get Dell to fix your laptop, despite it not being covered by the extended warranty, follow the instructions I have posted here: http://forum.notebookreview.com/showthread.php?p=4611553#post4611553
Dell is trying to cover up a critical flaw in what is supposed to be a high performance gaming laptop. It is my goal to make Dell come clean about this issue. Lets all let them know that they cannot get away with screwing over their customers like this.
Posted on Mar 13, 2009
Demmy is write, the only solution is to replace the motherbroad.
explained in this link- http://getsatisfaction.com/dell/topics/xps_m1210_battery_wont_charge_and_ac_adaptor_not_recognized
Posted on May 08, 2009
  • 59 Answers
Im not sure what the technician exactly meant. for portables, there are no jumpers to do that. We have the same case by the way. i replaced my motherboard and it works fine now.
Posted on Nov 25, 2008
XPS M1210 Laptop not powering up
No Power Issues on Laptops
There are 3 things to consider in order for you to determine a No Power Issue
1. Battery
2. Mother Board
3. AC Adapter
1. Remove the battery from the laptop
2. Disconnect all non essential cables (external hard drive, usb memory key, printer...etc.)just connect the AC Adapter
3. Take out the Battery....Usually there is a battery indicator that you can push at the back of the battery
4. By Now the battery power indicator should be full since it was never taken out
5. If still theres no light on the battery.... replace battery
6. Turn the laptop on without the battery
7. If the computer still did not turned on check the AC Adapter if there is light coming out
8. If there's no light that comes out from the AC Adapter. Reseat the cable from the AC Adapter to the Cord
9. Check if there is no light that comes out from the AC Adapter. AC adapter needs to be replaced
10. Otherwise the Mother Board needs replacing
May 17, 2011 | Computers & Internet
Dell Inspiron 6000 laptop periodically shuts OFF
You've checked the p/s and it has volts out. Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone. Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 04, 2010 | Dell Inspiron 6000 Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Dell XPS 1530 wont power on at all..
Troubleshooting is pretty simple.
  1. Try a different Dell 90W or larger D/E-Series AC adapter and see if the system gets power. If no known good AC adapter is available, then check output voltage of AC adapter (Should be about 19VDC or so) If you can't do either, then the AC adapter is still the cheapest item to replace for a no power issue.
  2. If system will not power on with a known good AC adapter or new one, then the motherboard is the likely failure point. Roughly $150 on Ebay
Feb 24, 2010 | Dell Computers & Internet
Xps m1210. Battery wouldn;t keep a charge,
Memory error
Resat the RAM, if you have 2 modules, try them one at a time
Jan 27, 2010 | Dell XPS M1210 Notebook
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Xps m1210 won't start
Before getting to that point are you sure your battery and power adapter are functioning properly? You may want to try each seperately and see if you get a response.
Mar 11, 2009 | Dell InspironTM XPS M1210 Notebook
Dell m1210 does not boot up - quickly powers off
I suspect the safety circuits is detecting a big power drain. What I would do is pull one thing off at a time and see if it stays on. Such like hard drive, memory, and anything else you can. Even disconnecting the LCD if you have too.
Another possibility is that your battery is bad. Try to boot up without the battery and just on AC. No help? Maybe the AC is bad. Try running on the battery alone and no AC.
That pretty much covers everything. If nothing works above, it is the motherboard. :(
Jan 30, 2009 | Dell XPS M1210 Notebook
Dell XPS M1210 Notebook Logo
1,156 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
