Question about ITT Night Mariner 160 Monocular
ITT Mariner 160 - How to open the case...
How do I open the case of my 160? I removed the five holding screws but the two halves of the case would not separate. I was concerned about using too much pressure for fear of breaking something. I need to re-seat one of the AAA battery contacts. Help and advice is needed. Fred1
  • massimo4545 Jan 16, 2008
    One of the two batteries contact broken, how can I replace?
    Have I to open completely the case?
    massimo.belfiglio@tin.it
    New Friend:
  • 18 Answers
This unit is siliconed together to make it waterproof and outer ring on eye piece is glued on after assembley you have to pry casings apart with knife ect not easy but they do come apart without damaging internal parts make sure you also remove casing screw under label as well i have dissasembeled about four of this model succesfully
Wayne
Posted on May 31, 2008
SOURCE:
After taking all the screws out I cannot separate the casing is there some kind of other hidden screw
Check for screws under any labels by feeling for depressions under them. If no other screws are there, then carefully press along the seam of the two halves to see if there are any plastic tabs holding them together. If you open around a tab, use something between the halves to keep them from re-locking.
Jun 01, 2015 | Video Game Consoles & Games
Repairs to ITT Night Mariner 160
ITT Night Vision
7635 Plantation Road
Roanoke, VA 24019
Telephone: 540-563-0371
Fax: 540-366-9015
Toll free: 800-448-8678
General email:
nv.orderadmin@itt.com
Call For Suppliers
Warranty Repair and Technical Support Toll free: 1-800-360-6054
Fax: 540-362-7400
email: nvwarranty@itt.com
Company Links ITT
ITT Defense and Electronics
Dec 19, 2007 | ITT Night Mariner 160 Monocular
Tip
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need servicing. The part most people have difficulty with is opening the case to get to the electronics. You will need a phillips screw driver and a small flat blade screwdrivers. You will first need to remove the stand, place a bath towel on a flat table, lay the monitor down and unscrew the screws holding the base and remove. Next you will need to remove any screws that are holding the back plastic case on, they will normally be in the 4 corners and possibly 1 in the bottom center of the back. Now take the small flat blade screwdriver and insert it between the two halves of the case in the center of the bottom. Be sure to not do this by the control panel so you don't break it. Gently pry the two halves apart. Most monitors will have several plastic latches around the perimeter of the case, usually 2 on each side that will need to be released. As you separate the case halves the latches will release and the back will separate from the front. You will need to unplug the control panel cable at this time before you can get to the electronics. Now you just need to use the phillips screwdriver and remove the metal shield from the electronics to get to the power supply. See pictures below.
Now release the catches as seen below:
Detailed monitor breakdown and repair information can be found on our web site at www.ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
on Dec 04, 2009 | Computers & Internet
Do you have to remove dashboard on a 1990 geo storm gsi to remove and reinstall the heater core. can you give me the step by step if the dashboard does not have to be removed.
log in to alldata.com and read that? its there?
anyone can,
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. remove core hoses passing thru fire wall.
  3. Remove the three duct mounting screws.
  4. Disconnect the duct between the blower assembly and the heater unit.
  5. Remove the five screws attaching the mode control case to the heater core case.
  6. Remove the mode control case. Do not remove the link assembly.
  7. Remove the five screws to separate the two halves of the heater core case.
  8. remove the core.
Feb 24, 2015 | 1990 Geo Storm
How do i replace the blade on my utility knife?
loosen the screw that is holding the two casing halves together and separate the halves. pay attention to which way the old blade is in the compartment, remove it and put in a new blade in the same direction. close the casing and tighten the screw
Jan 16, 2013 | Cutter Tools
My pen drive got into water for about an an hour......
As flash drives are so small, they are easy to put in a pocket and forget about, which can lead to an inadvertent trip to the laundry.
Most flash drives will survive a trip through the washer, as they are usually well sealed and have no battery.
It is important not to use the drive if any moisture is present, but once dried the drive should still be useable with the original data intact.
All that is required to save a wet flash drive is a bowl of uncooked rice
Dry the flash drive as much as possible with a piece of paper towel to absorb excess moisture.
Gently pry open the case of the flash drive if possible, using a small flat-blade screwdriver to separate the two halves of the case.
This is not essential, but will cut the drying time and will help to limit corrosion.
Dry the inside of the case as much as possible with the paper towel.
Pour some uncooked rice into a small plastic bag, and then place the flash drive in the bag and seal.
Place the bag in a warm, dry place for at least 24-hours.
The rice draws out and absorbs any moisture present, speeding up the drying time and ensuring the drive is completely dry.
Check the drive after 24 hours. If you can see any moisture, leave the board for 24 hours and repeat until the board is completely dry.
Reassemble the case, ensuring the two halves are tight shut. Use a small spot of glue to hold the two halves together securely if necessary.
You can then use the flash drive as normal
hope this helps
Oct 15, 2012 | SanDisk Open Box 1GB Cruzer Mini...
I have kingston datatraveller 100 G2 4gb its internal software had been gone since it had fell into water so plzz tell me link to download software
if it has fallen into water it might have been damaged beyond repair
the only thing you could try is to dry it out
leave it in a dry place
You can then use the flash drive as normal.
hope this helps
Sep 15, 2012 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Changed batterys no power black eye nothing
How long have you had this ITT Night Mariner 160 NV monocular? Sorry, it needs to taken a part and trouble shoot the electronic components and image intensifier tube. stewbison. If I had my shop set up but I sold all of my electronic test equipment. Contact ITT and ask them what to do. stewbison
May 03, 2011 | ITT Night Mariner 160 Monocular
Will not power on
Hello, these ITT Night Mariner 160 monocular are almost impossible to work on. To make them water proof every joint, hole, cap are epoxyed on. Check the internet and look for companies that manufacture materials that will desolve epoxy cement and even better stuff is that it makes the epoxy really soft for it can be removed. Sorry dude I couldn't be more help. stewbison
Mar 30, 2011 | ITT Night Mariner 160 Monocular
How to reset
Hello, Just remove the batteries. Also the batteries should be alkaline batteries. Not lithium, Ni-Cd, Mercury etc. Now, I'm giving you a little trick that I learn over many years work with electronics. Take piece of wire and make sure the batteries are remove. Take piece of tape and tape one end of the wire to the positive side (+), all it will be is little shinny plate. Now take the other end of the wire and tape it to the shinny spring this the negative side(-). Rember, there are two "AA" or "AAA" batteries.
The wire goes from + of 1st battery end in the battery compartment to negative side (-) of the second battery spring (-). Rember!! NO BATTERIES, while you are doing this operation. Let the wire stay on the battery terminal in the battery compartment for 5 minutes or so. What is does if the electrolytic capacitor is holding and want drop the current which switch is turn off, it will now.
Reinstall the correct batteries then turn on your ITT Mariner 160 monocular. GB...stewbison
Feb 03, 2011 | ITT Night Mariner 160 Monocular
ITT Night Mariner 160 Monocular Logo
406 people viewed this question
Top ITT Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
ray gallant
Are you an ITT Optic Expert? Answer questions, earn points and help others
