Question about Maytag MGR6772 Gemini Gas Kitchen Range
Bottom oven does not heat
I have a Maytag Gemini (MGS6772BDS) Double Even, the top oven works fine, the burners work fine, but the bottom oven doesn't heat. I cleaned both ovens, i removed the back panel of the oven and clean the entire stove. I wonder if the ignitor, valve and /or the burner is bad?
  • Anonymous Dec 07, 2008
    Me, too! Happened yesturday. I cleaned my oven 2 days before and used the next day, but now the bottom doesn't heat. It just shows preheat 100
  • 294 Answers
I ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Posted on Aug 02, 2009
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
Replace top burner outer coil not heating
Hi- There are a few on either side of the control panel assembly, under the covers. They like to hide them. Some models have connectors for the wiring harness to top, so you can remove whole assy. to work on it. Helps to have somebody hold top while plugging/unplugging though. Pay close attention to which wires go where when replacing element.  Let me know if this info helps- have more if ya get stuck! Thanks- Ed
Mar 18, 2010 | Maytag Gemini 30" Self-Cleaning...
Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Feb 03, 2010 | Maytag Gemini 30" Self-Cleaning...
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
Dec 08, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
653 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
