Question about kawasaki Full Suspension Mountain Bike Men
2004 KAWASAKI KXF250
JUST PUT TOGETHER A 2004 KAWASAKI KXF 250 AND IT WILL NOT START OR EVEN BACKFIRE IF YOU SQUIRT FUEL DIRECTLY INTO THE INTAKE AND KICK IT OVER.IT HAS PROPER COMPRESSION ;THE CAM AND VALVE TIMING ARE CORRECT AND IT SEEMS TO HAVE GOOD SPARK.IT ALSO HAS A COMPLETE NEW HEAD;NEW VALVES;NEW CAMS;AND NEW PISTON ;PISTON RINGS AND A NEW CYLINDER.EVEN HAD A LOCAL SHOP TECHNITIAN LOOK AT IT AND HE SAYS THAT HE CANT FIGURE IT OUT.PLEASE HELP ME I AM DESPERATE.
  • 3 more comments
  • hgtstang97 Nov 26, 2008
    THANKS.I TRIED THAT AND STILL NO LUCK.
  • hgtstang97 Nov 27, 2008
    CHECKED BOTH F THESE ALSO.STILL NO LUCK'
  • hgtstang97 Nov 28, 2008
    I HAVE AN EXTRA ENGINE AND STATOR AND SWAPED THEM BOTH AND STILL NO LUCK.IM REALLY STUMPED ON TIHS ONE!!!!!
  • gannut Dec 01, 2008
    Have same problem, bike use to start hot or cold well but went out on it one day, and would not start took it apart and found one ring stuck.
    New every thing in there put it all back together and still will not start new plug put in loads of spark all at right time and not a thing. Will not bump start so do not no what to say. For a bike that started so well hot! or cold, what else can i do.
  • James Mead
    James Mead Oct 25, 2017
    Give it a shot of starting fluid, if it fires a few times, try same again, if it runs for 2-3 seconds, you got fuel problems. No run or backfire, probably have spark problem, if you’re positive you have spark, replace the plug & try above scenario again.
    New Friend:
  • 41 Answers
Try a new plug sometimes a plug will not fire under compression. also adj the valves
Posted on Nov 25, 2008
  • Steve Worthey Nov 26, 2008
    check flywheel key, check ex pipe to see if stopped up
  • Steve Worthey Nov 27, 2008
    Hello, If all new parts are correct, timming is correct,you have good fire, then good chance your flywheel is bad
Oil amounts kxf250
It depends on the year of your bike, but most take about 1000-1100 mL(just over a quart). 946 mL per quart. There should be a sight glass on the bottom of the case that has lines on it showing your oil full level, and the bike has to be level to check for correct oil level. There is also usually casting numbers next to the fill hole that show how much oil to use (it will be in mL). Let me know if you need any more assistance, Daniel.
Nov 17, 2011 | kawasaki Motorcycles
I have a 2005 KXF250 and the bike continuously backfires when i let off the gas and wont stay running at idle. it dies even after its warmed up. whats up?
check/clean the carburator, adjust the air screw... lack of fuel, causing the the engine to backfire when you close the throttle... adjust idle...
Jun 04, 2011 | 2005 kawasaki KX 250
Hi there i have a kxf 250 2004 its hard to start and when it does it back fires alot could it be valves
It could be valves , check all the valve clearances.
also try a new spark plug
and clean the carb
a faulty kill switch can sometimes cause backfire as well
Aug 10, 2010 | 2004 kawasaki KX 250 F
What is the proper valve setting on a 2006 kxf250
From an 05 kxf, intakes are +/- .005 and exhaust is +/- .008..... They should be the same with 06 to 09.
Apr 29, 2010 | 2006 kawasaki KX 250 F
Hi my name is allen i have a 2004 kawasaki kxf250 and i need some help i dont no how to set the timing on it
take off the cam cover look at your cam and there should be two lines on either side, make sure the bike is on top dead center and put the cam to where the two lines are level with the head. count 26 pins from line to line.
Apr 21, 2010 | 2004 kawasaki KX 250 F
I have a kxf 250 2007 with an electrical problem that i cant find
bad spark plug, tight valve clearances,short in key switch or kill button, blocked fuel filter (There is usually one inside the tank on the fuel tap pick up)
Apr 12, 2010 | 2007 kawasaki KLX 250
2004 kawasaki kxf250 its stuck in gear
More than likely you have a transmission issue. Could be a bent shifting fork, or a worn shift drum. It probably needs to be split, or opened up to determine.
Nov 13, 2009 | 2004 kawasaki KX 250 F
Need to know the specs of kxf250 kawasaki camshaft
buddy try this site
http://www.cornwallkawasaki.co.uk/shop/shop.php?cmd=listcomponents&id=Kawasaki%20Motocross&model=2004%20KX250F%20N1
Oct 03, 2009 | 2004 kawasaki KX 250 F
kawasaki Full Suspension Mountain Bike Men Logo
1,795 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
