Question about Sony WEGA KD-34XBR970 34" TV
Sony LCD cutting off image when hi-def cable hooked up.
I cant turn my 36" Sony Wega LCD flat screen tv -wide mode- to "normal", it is shaded and not available, I can only select "wide zoom", "full", "zoom", and when I have hi-def hooked up and go to a normal(non hi-def) tv channel, it cuts a small part of the image off, like maybe 10%. So the only way I have found to fix this is to unhook the hi-def cables and use regular yellow rca plug.
  • shelbyzz Nov 25, 2008
    Well, maybe I found the problem - my cable box was set to partial zoom. but still why cant I select "normal" on my "wide mode" setting?
    Thanks
    Top Expert:
  • Sony Master
  • 12,962 Answers
This will happen invariably. Depends on the nature of the signal that is being received. Some will fill entire screen, others will not.
Just go with the flow - tv is operating normally.
Posted on Aug 23, 2017
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: How do I replace the TV tube in my Sony Wega 36" flat screen?
Hello jmdady,
First I would like to say that this procedure is dangerous, and should only be done by a qualified Television Technician.
With that being said here is how I would do it:
1) unplug TV and remove the back panel of the TV set.
2) discharge the anode voltage of the CRT by using a screwdriver attached to a clip lead which is attached to the ground of the TV.
3) Remove the chassis of the TV as per the instructions found in the service data (you will need to buy the schematic diagram and the service data sheets for this set)
4) with the chassis removed and the HV anode removed from the CRT, lay the TV face down on a soft surface (a folded towel or a large foam pad).
5) Remove the yoke transformer and the convergence rings by releasing the holder ring and slowly moving the assembly up on the neck of the CRT until the whole assembly is free.
6) Unscrew the 4 retaining brackets and remove the retaining assembly from around the tube (this includes the grounding straps
7) Once the retaining assembly is removed, pick the tube up by the sides (DO NOT USE THE NECK OF THE TUBE TO LIFT THE TUBE UP).
8) Once the old tube is out, put the new tube in its place.
9) Reinstall the retaining brackets and the grounding strap and screw the assembly back in place.
10) put the yoke transformer back on to the set, using the same spacers and mounting equipment but do not tighten the holder ring (you will need the yoke and color rings to the loose to adjust purity and convergence)
11) Reinstall the chassis as per the schematic, reconnect the HV anode, the CRT board, and the connections to the Yoke Transformer
12) At this point you will need a color pattern/bar generator, a mirror, and a lot of patience because you will need to adjust the yoke on the TV and adjust color purity, and convergence (Read the schematic as to the recommended signal levels, and patterns to use).
This is the procedure I would use. Now I suggest that you have a qualified TV technician do this because there are certain dangers involved in this procedure. THIS IS NOT SOMETHING YOU SHOULD TRY TO DO YOURSELF.
I hope this helps,
Thank you,
Shuttle83,
Http://www.electron-age-technologies-llc.com
Posted on Dec 07, 2008
jerryg50
  • 1689 Answers
SOURCE: Sony 36 Wega XBR Flat Screen - sudden death.
This could be a scan amplifier failure, and there is a loss of high voltage to the CRT. Part of the power supply may have also failed. In these sets, if the CRT emission goes low in emission, or the CRT goes defective, the bias supply to the CRT will go in to protect.
An experienced TV service tech can troubleshoot the set and give you an estimate for service. Considering the age of the set, the cost of service may not be worth it.
Jerry G.
Posted on Jan 08, 2009
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The xcreen is to wide
Press the "Screen Mode" button on your remote control to cycle though all available screen modes.
Mar 05, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Image too big for screen
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sony WEGA  KD-34XBR970 34" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
