Question about Locks & Locksmithing
Question I have a 0.7 cu. ft. Microwave oven by Magic Chef. The model # is MCB780W I purchased this one on Jan this year. It's not really working. When I plugged in, I would hear a beep sound and 0 is shown initially. But, few seconds later, it shows 3.5, then sometimes it stops in this status or starts to cook. In both cases, no button works. I found out something wrong yesterday. I was in a living room and heard a sound that the microwave oven was starting to cook automatically. Nobody set timers. then, I plugged off, and now I have this problem. Would you please let me know how I should solve this? geshek@hotmail.com
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 02, 2008
  • 82 Answers
SOURCE: Magic Chef won't work - clock works
Does the fan run?
If not, it's a control board fault.
If it does run, it's probably a high voltage problem.
Posted on Mar 16, 2009
  • 14 Answers
SOURCE: I have had the powerbolt 1000 for two years and it
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Posted on Sep 14, 2009
rsmith972278
  • 160 Answers
SOURCE: After many years of use, all of a sudden it starts
It sounds to me as if you are getting the three wrong entries alarm. Why I don't know. Try reprogramming to a different code and see if that helps. I'm including a Link to Weiser PDF Manual to do this , just in case.
CLICK BELOW
http://www.weiserlock.com/PDFs/install_sheets/pb_eng_install.pdf
Hope this Helps,
RSMITH972278
P.S. CONTACT ME IF YOU NEED TO
P.P.S PLEASE RATE ME !
Posted on Oct 17, 2009
Testimonial: "I ended up having to buy a new unit, but a good response to my question plus the PDF file was very helpful"
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Where can i buy a plate for me my mcb780w microwave.
Repairclinic.com carries a replacement glass tray for your microwave for about $23. Just type in your model number and you will find the tray listed as item 1206615. I hope this helps you.
Dec 15, 2009 | Magic Chef MCB780W Microwave Oven
Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Sep 27, 2009 | Magic Chef MCB780W Microwave Oven
Magic chef mcb780w
MCB780W - May 27, 2017
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
You likely have a shorting membrane keypad. MCA's parts site is not showing keypads or controller parts as being available for this model, but they may be.
You can contact them here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 22, 2017 | Microwave Ovens
Mcb780w won't work
Chances are its the fuse on the circuit board. You will have to remove the outer shell of the unit to access it.
clarkco
Feb 27, 2009 | Magic Chef MCB780W Microwave Oven
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
Defective microwave
I would definitely contact the manufacturer since most of them have a one year parts & labor warranty and they'll fix it free.
If you have your owner's manual, you can find their number. If not, please reply back with your brand and model number (or brand at least) so we can help you.
Sounds like a bad door switch or relay, and also possibly a bad magnetron or high voltage diode.
May 29, 2008 | Magic Chef MCB780W Microwave Oven
Glass Tray table size?
Visit Magic Chef online and click the Cusomter Service link at the top: http://www.magicchef.com
Apr 03, 2007 | Magic Chef MCB780W Microwave Oven
Locks & Locksmithing Logo
152 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
