New wide screen monitor incompatibility issues with older comp
Just replaced my old monitor with a wide screen 16:10 monitor.
I tried 2 new video cards & niether worked.
They were Gforce Nvidia cards & both had issues with a device resource ( Win 2k code 12 ). mem range unavailabe.
mobo is old VT82c598mvp
current video card is old ATI Rage Pro agp 2x
All I require is basic compatible graphics. ( No heavy gaming )
What do I need to do ?
  • peetree Nov 25, 2008
    The old rage pro card runs the screen but doesn't accomodate the 1680 x 1050 screen resolution.
    images are distorted, too wide.
    I can compress the horizontal width to it's max with the monitor controls but this still leaves images about 12% "too wide" distortion, & annoying vertical lines appear.
    The monitor driver is installed, but in display "settings" the only option showing for high res is 1600 x 1200.
    I think the old rage pro card doesn't know about wide screen settings. It's from way back in 1999.
    I'm hoping hoping someone might know of a specific mid range card that would work with the old motherboard. I think it's from 1999 too.
    thanks again
    pete
  • 153 Answers
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Posted on Nov 25, 2008
  • Trevor Sauna
    Trevor Sauna Nov 25, 2008
    Try installing the driver for the moitor, it might help with the resolution properties.
  • Trevor Sauna
    you're welcome.
I am trying to play the game on my comp. But the display does not use the entire screen. Is there a way to adjust the size?
Modern Games need Wide Screen Monitors.
If you are playing old games on a wide-sreeen monitor, temporarily set the monitor resolution to 1024x768 or 1280x1024.
Aug 21, 2014 | Computers & Internet
Remanufactered cartridges no longer work with my Epson cx7400
It's entirely possible the problem is one of the following:
Recently replaced cartridges have
1. incompatible chips for your printer (ie: they're the wrong type)
2. chips that don't talk or work with the type on your older/original cartridges.
The issue with 2. usually comes about when consumables are from different suppliers or the supplier has switched to a new version that doesn't work in the same way as the earlier brand.
Fix in either instance is to either:
- replace the older cartridges with new types across the board
- try reinserting the old cartridge(s) to make sure the problem isn't more serious (ie: logic board or contact wire failure).
Note: contact wires are the little delicate wires that make contact with the chips. They are easily broken off if there's rogue plastic flashing or similar on cartridges or small children try to "fix" things.
Hope that's of some help.
Dec 15, 2012 | Epson Stylus CX7400 All-In-One Inkjet...
Since new monitor, computer shuts down dislpys
try adjusting your herz default is 60hz most of the time
Have you tried a old display again and worked?
mabe just bad Monitor try on dif computer see if you have the same results.
another thing would to be update the driver for the video card mabe compat. issue with older card newr monitor
Dec 21, 2009 | Cars & Trucks
Have black area on right side of screen and can't get full screen
What video-card does your computer have?
Some older video-cards do not support "wide-screen" monitors.
Thus, they only "paint" 80% of the width of the screen.
Oct 09, 2009 | Acer X203W 20" LCD Monitor
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
ATI RADEON X800 GTO AGP
can u take it out boot up for 20 sec shut down reaset it in and plug it in useing differt plug ok push it in good then cheak fan on it blowing or not if not unplug it get a fan on it
Jan 23, 2008 | ATI RADEON X800 GTO, (256 MB) PCI Express...
Screen prob.
For flat panel systems there are 2 inputs. DVI using the white cable and VGA. by default flat panels are set to DVI input. hit the menu button on the screen and there should be an option there to change the input video. if this will not work it could be a problem on the video port on your acer computer or it could you might need a new VGA cable.
Oct 11, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Resolution problems
Colsult your user manual or online documents, this may be an incompatible resolution for your monitor, whatever it is.
Oct 03, 2007 | Gateway FPD2275W LCD Monitor
Open Questions:
Computers & Internet Logo
640 people viewed this question
David Payne
David Payne
