Question about Kenmore 83042 Electric Dryer
Drum is hard to turn
I was unloading my dryer and I usually spin the drum around to see if there's any socks stuck to the sides, and when I went to spin it, it felt really heavy like something was stuck inside and sounded like something was dragging. Everything was dry when I pulled it out, but I'm afraid to dry anything in case the extra strain of turning the drum burns out the motor. Is there an easy way to open it up besides from the back to see if there is any clothes trapped inside?
  • 2 more comments
  • Candice Charlson Jan 03, 2007
    We took it apart and there wasn't anything stuck, the noise is from the felt on the door that the drum sits in. We looked at the ball in the back and nothing seems to be worn, we greased it up and it's still moving stiff. I don't recall hearing the rubbing noise from the felt on the door before, and it was definitely easier to turn a few days ago when I used it. We noticed it's thinner on top than at the bottom, so could that be the issue? If so, how expensive is that to replace?
  • Candice Charlson Jan 16, 2007
    We replaced the drum glide felt on the top of the door where it looked worn down, and now it's really hard to turn. The ball on the back of the drum looks fine and the plastic cup in the back doesn't look worn out - still have to force the ball in and out. The belt doesn't look as if it has moved from the rubbed spot it's left on the drum and it's still tight. We called someone to see if they could help out with a suggestion and they said the model number we gave them isn't the right number, but there isn't any other number on the machine. The only one is the marker number written on the back. It had to have been made in either 2003 or early 2004 - we bought it between March and May 2004. It's a stackable with the flat top and the knobs on the front.
  • Candice Charlson Jan 20, 2007
    It looked the same as what we took off, the plastic is on the drum and felt is on the front panel. We're going to try greasing up the felt because no one seems to have any better ideas.
  • jayumc Feb 27, 2009
    I have the same problem, the drum is unusually hard to spin, and the drum is now making a rubbing noise. The inside kinda smells a little nasty (not usuall like this)...burnt almost. Yes there seems to be a different model# (mine #80042-00) ad the one I have seen on this page. They are one and the same though.
    I plann on taking it apart before I buzz a tech, any other advice would be greatly apreciated.
  • 3 Answers
Does your dryer have a plastic glide on the drum or is it on the felt if some one gave you the wrong one that would make your problem worse there is two different types for that dryer
Posted on Jan 20, 2007
Dryer is getting very noisy. Does this mean there is a problem ?
The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.i think i will work out
Dec 16, 2010 | GE Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
When I press the start button on my Kenmore dyer it make a noise but won't start
if it's a humming or like a buzzing noise it's coming from the motor.try spinning the drum by hand,if it moves freely it could be the motor,if the drum is hard to move you could have something like a sock stuck in the blower wheel or something is jamming up the machine and the motor can't move.also just yesterday i found the belt broke and was rapped around the motor so you'll have to get in there and take a look.good luck,let me know what you find
Jun 27, 2010 | Kenmore 63942 Dryer
My clothes are sopping wet when the wash has finished and there is water at the bottom of the drum. I can sort it by taking clothes out, bailing out the water and then re-spinning the clothes twice to get...
Sounds like a blocked outlet pipe. It may be possible that a small item of clothing i.e. sock or baby item may be stuck between the drums and occasionally moves over the outlet from the drum causing the blockage, hence only happens once in a blue moon. To see if you can see if there is something between the drums use a flashlight to help you look through the holes in the inner drum to see if there's a stray sock or something that can be moving around between the drums and covering the outlet. If there is then you will have to remove the outlet pipe from the bottom of the drum to try and remove the item that is causing the blockage, check all the way around the drum as it may be stuck to the inner drum at the time. If no item is found between drums then the blockage may be in the outlet pipes (both sides of the pump) or in the pump. Check these also as it may even be a small button or coin creating a blockage if it is moving around.
Feb 25, 2010 | Hotpoint Aquarius WD63 Front Load...
The motor hums but if i take off the tension spring the motor spins fine
if you mean you disconnected the belt and the motor spins you could have something stuck in the blower wheel like a sock or something,you might have had the filter out and ran the dryer and something went down into the blower wheel,also the motor still could be bad not strong enough to spin drum
Nov 02, 2009 | Maytag Dryers
Dryer does not start. Drum does not turn by hand. Only makes a sound when switch is turned on.
If it is a sound like a loud hum, the motor is either fried or something is jammed preventing the drum from turning. It could be something like a sock. You just have to open things up and look around carefully, especially around the outside of the drum.
If the noise is a more normal one but the drum is not turning, check that the belt is around the drum and not broken. Some drums are just fairly hard to turn by hand, partcularly if the belt is still around the drum.
Sep 19, 2009 | Dryers
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
Drum not turning properly
Check the belt and see that it is not worn down, kind of like a fan belt on a car. You may want to replace it anyway. next, the motor be be loose from the frame it is fastened to. Feel the surface of the drum for any grooves or worn places. There may be build up of debris. You can take off top of dryer to gain easier access to the drum.
Jan 12, 2009 | Kenmore 659 Electric Dryer
Drum Stuck
First, take off the top of your dryer. Use a screwdriver to pry the top up in front, then it's usually held on by some swing metal hinges on the back that simply come off by themselves as you rotate the top of the unit up and back. Then, you should be able to see all the screws and metal brackets holding the front of the unit on, remove all of these and you should be able to pull the front off. It may be necessary to unplug some of the wires when doing this. Then you should have full access to the front lint filter section on the door, and the fan section underneath the drum. The fan and the drum spin together, so if the sock is stuck in the fan that will also stop the drum. Good luck
Nov 30, 2008 | LG DLE2512W Electric Dryer
Some of my clothes are coming out of the dryer with black streaks in different places, sometimes i can see that a corner of a tea towel or similar has got stuck in the rim and wondered if this is causing...
Does the temeperature appear to higher than usual?
Does the dum spin correctly (smoothly and at a constant speed)?
I am thinking that the rubber belt that spins the drum may be getting hot somehow and melting bits in the dryer holes of the drum.
Is the drum stainless steel or painted?
There are generally no other components that can come in contact with the contents of the clothing.
The only last thing I can think of is whether a piece of dark clothing (i.e a sock) has queezed behind the drum and moisture is picking up the colour.
Sep 16, 2008 | Dryers
Kenmore 83042 Electric Dryer Logo
1,480 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
