Question about Optoma H30 Multimedia Projector
Picture is green with some purple shades
I have an optoma h78DC3, have just replaced the blub and cleaned the filter. I read you can shoot some air thru it to blow it out some but so far still get the same results. I have it ceiling mounted and inverted. I live in Roswell Georgia. Is there a repair store nearby that can fix this. Are there other things i can try to do to fix the color problem.....it has worked great up to now. I have seen some info regarding a color wheel but i do not know what that is ........the manuels dont show any maintenace or real instruciton other than some user adjustments and installation type stuff
Help I want to watch on the big screen
TV mojo
  • inuyasha8 Feb 17, 2009
    I have the same problem but its in certain areas on my television, but it sits on an enterainment center on the ground? Any suggestions to that one??
  • knsprao Feb 21, 2009
    we  are  having  a  NEC  LCD projector. When  efforts  were  made  to clean  the  lense by menu adjustments the  picture  gets  inverted.
    Please  inform  the  method  of  resetting  the  LCD  projector  to normal condition
    KNS PRAKASH RAO
    INDIA
    Problem Solver:
  • 3 Answers
I don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Posted on Dec 22, 2008
Does the Optoma HD20 DLP projector have a air filter?
yes, any projector with a air filter.
if your projector often make overtemperature protection, you have to inspect the air filter,whether it is still clean, otherwise, you need to replace it.
Jul 09, 2014 | Optoma Hd20 High Definition 1080p Dlp Home...
Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Mar 26, 2010 | Optoma EP7155 Projector
My Optoma 732B Projector is projecting in unusual colours.
before you use your sledgehammer, make sure its not the device outputting the discoloration, or bad connections
Mar 18, 2010 | Televison & Video
Green power light flashes
Is it time for a lamp replacement? perhaps a cleaning of the air filter? check these two before looking into a service for it.
Jan 15, 2010 | Optoma EX530 Video Projector - 2600...
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Televison & Video
Sony KP-46WT500 picture is distorted
you either need to reconverge the unit (auto focus) or you need to replace the converge chips-stk-xxx-xxx don't adjust anything.
Nov 05, 2008 | Sony KP-46WT500 46" Rear Projection...
Optoma H30 Multimedia Projector Logo
355 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
