Question about GE Dryers
Ge Cloths dryer will not stay running or turn drum
I have a GE dryer model DX4500ee1ww. When I turn the start switch I can hear the motor run, but the drum does not turn and as soon as I let go of the switch it turns off. The drum can be turned by hand easily. I replaced the start switch but it did not fix the problem.
    Genius:
  • 1,028 Answers
Probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Posted on Nov 25, 2008
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Pushed start switch and making huming noise and won't start ge gas clothes dryer model dvlr223gg8ww
In most cases the motor is seized or something is preventing it from spinning (seized drum wheel for example).
Feb 10, 2015 | GE Dryers
Why doesn't the dryer stay running when I let go of the start switch?
Hi, There is only one reason I can see the dryer stops after you let off on the start switch is the motor because GE motors has start switches either built inside the motor which is non removable or built outside the motor which can be replaced .
Its called a motor start switch and the way to locate it is to remove the front panel on the dryer and remove the drum and belt and then write down the motor model number and look at all the wires that go into the motor which is your motor start switch that is held in by two screws but before you remove it don't forget to copy the wire down on piece of paper of how you remove them .
If you don't see a black switch to the motor then its built in and the motor needs to be replaced.
Oct 23, 2014 | GE DWSR483EBWW Electric Dryer
Not sure of model but dryer does not stay running when switch is released. As long as you hold switch on it runs and when you release it shuts off. Suggestions?
Check the belt is not broken . If the drum turns when you start it then either the belt switch is bad or the motor switch is not working because it is bad or the motor may be full of lint.
Nov 17, 2010 | GE DBXR463EDWW Electric Dryer
I have a GE DX4500EE1WW electric dryer. Over the weekend it stopped working. If you turn the start dial you can hear it hum so I know it's getting power but the drum won't turn. I've tried it on every...
MOST LIKELY A BAD MOTOR OR SOMETHING CAUGHT IN THE BLOWER WHEEL. UNPLUG UNIT, TAKE TOP PANEL OFF AND THEN FRONT PANEL. PULL THE DRUM AND BELT OUT AND LOOK INTO BLOWER HOUSING FOR RESTRICTION AND SEE IF YOU CAN TURN MOTOR BY HAND.
Oct 06, 2010 | GE Dryers
My brand new GE profile frontloader dryer quit spinning. Still blows and I can hear the motor. Other than that no odd sounds and the drum spins manually without resistance. Model DPVH890EJMG How do I fix...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | GE Dryers
Dryer will not stay running unless you hold start switch.
DOES THE DRUM TURN OR JUST THE MOTOR KICK ON TILL YOU LET GO OF THE BUTTON. SEE IF YOU HAVE A BROKEN BELT. THERE MAY BE A SWITCH THAT KEEPS THE MOTOR FROM RUNNING IF THE BELT BREAKS.
CHECK INSIDE DRYER TO BE SURE A LOT OF LINT IS NOT ON TOP OF MOTOR. THE LINT CAN INTERFERE WITH THE CETRIFIGUAL SWITCH THAT IS LOCATED IN THE MOTOR.
IM SURE ITS THE BELT
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
NEW JERSEY
WWW.LARTODAY.COM
Dec 11, 2009 | GE DBXR463EDWW Electric Dryer
GE electric dryer (model #DDE5300BBLAD) won't start when I hit the start switch. I do hear a noise when I hit the start switch...stops when I release the switch.
the sound you hear is the motor trying to start.reach in drum and turn clockwise 1 revolution.try to start it again,if it starts your motor is starting to go bad and will have to b e replaced soon.if you canrt turn thje drum you probably have something stuck in blower below lint filter .hope this helps .please rate my response:)
Dec 09, 2009 | GE Dryers
GE Dryer won't start without help
YES THE MOTOR IS BAD,TO WEAK TO TURN DRUM ON IT'S OWN,IF YOU GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR MAYBE YOU CAN FIND ONE CHEAP ON EBAY-MIKE
Mar 05, 2009 | GE Dryers
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
Dryers Logo
268 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
