Question about Nokia 2100 Cellular Phone
Contact service as i open the unit, contact service was displayed. how and what should be the thing i must do?
  • 68 Answers
First you flash your phone and check imei on the software
other vise change cobba the aduio ic
i hope it will work
Posted on Dec 17, 2008
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Solution 1:
  • Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
  • Flip open the top of the printer.
  • Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
  • After you move the laser, unplug the printer for a few minutes.
  • Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative
+1-855-517-2433(Toll Free)
Nov 25, 2013 | Canon LASER SHOT LBP-2900 Printer
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
I have a sharp vl z300 displaying an E007 FAULT .CAN YOU HELP WITH WHAT IT IS AND IS IT WORTH FIXING
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
Jul 29, 2011 | Canon LASER SHOT LBP-2900 Printer
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
Apr 16, 2011 | Canon LASER SHOT LBP-2900 Printer
I am seeing the code H02 on the display panel when attempting to play a DVD. I have attempted to play several different DVD's. I have also switched the unit to standby mode then back on. I then...
This is what the manual says:
Trouble may have occurred. The number following "H" depends on the status of the unit.
Reset procedure:
Press [POWER ?/I] to switch the unit to the standby mode and then back to ON. Alternatively, press
[POWER ?/I] to switch the unit to the standby mode, disconnect the AC power supply cord, and then
reconnect it.
If the service numbers fail to clear, note the service number and contact a qualified service person.
I know these things you have tried so here is the contact information for customer service:
In the U.S.A., contact the Panasonic Customer Call Center at
1-800-211-7262, or e-mail consumerproducts@panasonic.com, or the
website (http://www.panasonic.com).
Mar 01, 2011 | Panasonic DVD-S35 DVD Player
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
My computer wont open
Hi woc169! Your problem may be related to an HP recall/repair announcement regarding left side hinge defects. Go to http://www.hp.com/#Support or call the number at the end of this message. Hope this helps!
HP Limited Service Enhancement for Left Display Hinge
HP has identified a hardware issue with certain HP Pavilion dv9000, dv9100, dv9200 and dv9400 series notebook PCs.
Step 3: Identify the symptoms Ifyour computer’s product number is listed above, and the notebook PCexperiences one or more of the symptoms listed below, contact HP duringthe Duration of the HP Limited Service Enhancement to determine whetheryou are eligible for a free repair. Symptoms of a broken left display hinge include but may not be limited to the following:
  • Whenopening or closing the display panel, you may hear popping or cracklingsounds from the bottom left corner of the display (left hinge area).
  • When opening or closing the display, the display may feel loose or wobble in the lower left corner.
  • The plastics surrounding the left display hinge may show cracks or breaks.
Service enhancements and free shipping
NOTE: This HP Limited Service Enhancement program is available in the United States and Canada through May 31, 2009.
  • Free shipping Ifyour notebook needs to be returned to HP for repair, the shipping costsare free. HP will immediately send you a postage paid container inwhich to send in your computer, and we will pay the return shipping. AfterHP receives your notebook PC, HP will use its best efforts to repairand ship your notebook to you within 10 to 14 business days.
  • Post-service warranty The HP repair warranty covers the left hinge repair for 90 days after HP returns your notebook PC.
Contacting HP To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Jun 06, 2006 | RCA RT2500 System
Nokia 2100 Cellular Phone Logo
132 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
