Changed screen on 5602 acer laptop and the inverter board
Still can not see files. if i put on an external monitor it is working fine.
what else can i do ??????????
  • vlbarron Nov 25, 2008
    the screen is dimmly lit. where can i find some place to adjust it to bright? i have a new inverter and new screen. could it be a software issue? with the acer 5602?
    Genius:
  • Computers & ... Master
  • 1,673 Answers
Did you check that the brightness control is turned up?
The main power inverter, or the LCD interface driver circuit area on the monther board may have a fault.
Jerry G.
Posted on Nov 25, 2008
  • Jerry Greenberg
    Jerry Greenberg Nov 26, 2008
    I don't know the details for your laptop. You should consult the user manual about how to control the brightness of your screen. With my laptop I press Fn + (arrow left) or (arrow right) to control the brightness.
    I have seen various hardware failures cause brightness problems.
    Jerry G.
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
Advent 5431 screen all mashed up ie cant workout what anythink says on the screen at all,when i plug in external monitor screen is ok..changed screen with a working laptop screen and changed inverter still...
Most probably you have a defective LCD screen cable. This is the only possibility left since you have changed the LCD screen & inverter, & an external monitor works fine. Check your LCD screen cable & replace it if necessary.
Oct 22, 2010 | Acer Aspire 4720 Notebook
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor...
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 07, 2010 | Toshiba Satellite M115-S3094 Notebook
Acer netbook AO751h screen does not work, external monitor works fine.
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Sep 20, 2010 | Computers & Internet
Blank screen on my acer laptop, it boots up, and i have put it on an external monitor, and it brings the screen up on the laptop,also tried changing the screen from 1 to 2 so the lcd is not broken, tried...
If an external monitor works fine then maybe you're having issues with the LCD's backlight. It happened to my laptop and I had to replace the whole LCD itself.
May 11, 2010 | Acer TravelMate 7120T (91.42A01.605) PC...
Acer 5620 Black Screen, but can just about see an image there. I have tested my laptop screen on another laptop and is working fine. Laptop works fine on external monitor. Looks like it is a motherboard...
Hi:
If you have tested your screen, then the problem is most likely the LCD inverter assembly. It is usually mounted near the bottom of the LCD, is a tiny circuit board, approx 1/2" wide by 4" long. it is what powers up the backlight on the LCD, and they don;'t cost too much, maybe $15...Hope this fixes it!
Apr 23, 2010 | Acer Extensa 5620 Notebook PC
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Flicker
if you have screen Flicker, this could be several Things. Faulty or Failing Inverter Board, Or tft screen tube failing ( usually determined by occasional Pink Screen At Startup ) try to use an external Monitor. if it,s fine on an external. this will eliminate motherboard or graphics chip fault.
Mike @ compurepair.
Sep 05, 2009 | Acer Aspire 4520-5803 Laptop
Acer Aspire 6530G black screen
There's no point getting a crisis program if you cannot see the screen in the first place.
The problem could be anything from a faulty graphics, faulty motherboard or loose cable or inverter board.
To test this connect an external monitor to the laptop and use the keyboard toggle to switch screens (hold down Fn and press the F key that has a monitor icon on it)
If the external monitor has a display on it then the problem is the inverter, inverter cable or the screen itself which if faulty.
If there is no display on the external monitor you maybe looking at a new laptop.
If you have no external monitor to test then look very close at the laptop screen, if you can just make out an image then its the inverter.
Post back if you require any more assistance.
Regards.
Sep 02, 2009 | Acer Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
