Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Stops in the middle of the wash cycle
My dishwasher runs part way thru the wash cycle and then stops washing. It does continue a blipping noise that isn't loud, but still isn't washing the dishes. It will stay there forever unless I manually turn it off. I can then start the wash cycle again from the beginning, and it does the same thing all over again, runs for about 20 minutes on the wash cycle and then stops washing but with a blipp, blipp, blipp noise. Anything I can do, is it the computer chip ? I know nothing ! Thanks !
  • Anonymous Jun 19, 2008
    have the same problem as above.ran the automatic function test successfully with no errors or malfunctions
  • ernie15 May 11, 2010
    I have a similar problem but I do not have the diagonstic sheet you mentioned. Apparently the installers took it with them. Can anyone email me a copy?
Same problem, it was a poor solder on the main control board. I pulled the inside cover off the front door and saw where the circuit board had gotten hot. The little blue box was loose so I pulled the circuit board loose, flipped it over, and resoldered it.
Posted on Jul 15, 2008
HAVE THE SAME PROBLEM WITH THE SAME MAYTAG MODEL DISHWASHER. THE PROBLEM IS WITH THE CONTROL PANEL ASSEMBLY HAVING ONBOARD COMPONENTS NOT SODERED CORRECTLY TO THE MAIN CONTROL BOARD. THESE LOOSE OR COLD SOLDER CONNECTIONS HAVE TO BE REHEATED,RESOLDERED WITH A SOLDERING IRON . THE ON BOARD COMPONENTS THAT I WAS HAVING PROBLEMS WITH WAS THE BLUE BOX LOOKING COMPONENT,SOLID STATERELAY, AND THE RAISED RESISTOR,HAS COLORED BANDS AROUND IT. THESE COMPONENTS ARE LOCATED ON THE LEFT SIDE OF THE PRINTED CIRCUIT BOARD FACING THE DISHWASHER LOOKING OVER THE TOP. TO MAKE THE REPAIR, TURN OFF THE CIRCUIT BREAKER TO THE DISHWASHER, OPEN THE FRONT DOOR AND REMOVE THE 10 SCREWS THAT HOLD THE DOOR TOGETHER. THIS WILL ALLOW ACCESS THE THE CONTROL PANEL.. IF YOU DO NOT FEEL QUALIFIED TO MAKE THIS REPAIR USING A LOW WATTAGE SOLDERING IRON YOU CAN ORDER THE CONTROL ASSEMBLY LED FROM PARTSSELECT.COM. FOR ABOUT 100 DOLLERS. THEY ARE ABOUT THE CHEAPEST. FOLLOW THE ON SCREEN INSTRUCTIONS TO ORDER THIS ASSEMBLY.THE ASSEMBLY PART CAN BE FOUND IN THE CONTROL PANEL PARTS ILLUSTRATION. WHEN SEARCHING FOR THIS PART YOU MUST SEARCH USING YOUR DISHWASHER MODEL NUMBER. THIS INFORMATION CAN BE FOUND ON THE LEFT SIDE OF THE TUB OF THE DISHWASHER AFTER OPENING THE FRONT DOOR. ALSO, WHEN LOOKING FOR THIS PART IT WILL BE LISTED TWICE,AS SERIES 10, OR SERIES 24. YOU MUST ORDER THE CORRECT SERIES. THE SERIAL NUMBER ON THE SAME PLATE THAT THE MODEL NUMBER WILL PROVIDE THIS INFORMATION. IF YOUR SERIAL NUMBER STARTS WITH A 10 ORDER THE SERIES 10, WITH A 24, ORDER THE SERIES 24. WHILE YOU ARE ORDERING CHECK YOUR LATCH HANDLE, THE SIDE PIN WAS BROKEN MAKING IT HARD TO OPEN THE DISHWASHERS FRONT DOOR. ONE OTHER THING YOU MIGHT WANT TO CHECK IS THE FLOAT SWITCH OPERATION. MINE WAS STICKING. TO ACCESS THIS REMOVE THE 4 SCREWS THAT HOLD THE PANEL .THE FLOAT SWITCH IS LOCATED TO THE LEFT.WITH THIS PANEL REMOVED CHECK FOR ITS FREE NONSTICKING OPERATION. IT CAN BE DISMANTLED AND CORRECTED. A SERVICE SHEET IS LOCATED, ATTACHED TO THE INSIDE OF THIS PANEL.IT HAS GOOD TROUBLESHOOTING INFORMATION INCLUDING A AUTOMATIC FUNCTION TEST.THIS TEST PROVIDES A DIAGNOSTIC ANALYSIS THAT WAS EXTREMELY HELPING FOR ME TO DETERMINE MY PROBLEM AND CORRECT THE MALFUNCTION CONSIDERING I AM NOT A APPLIANCE REPAIRMAN. I HOPE THIS INFORMATION IS BENEFITICAL. REGARDS.
Posted on Jun 21, 2008
  • billy44bob44 Jun 06, 2011
    I also had the same problem with my mdb9150aws -- Stpoped part-way through the cycle, blinked, then eventually lights just blinked. One of the wires connected a blue box had become disconnected so I reconnected it by soldering and then the problem was fixed.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Have a Whirlpool dishwasher model GU1200xtks. It is at least 8 years old. The dishwasher is malfunctioning. Sometimes the panel lights does not turn on but it sounds like the motor turns on automatically...
Bad touchpad user interface, is sticking in cancel mode causing unit to drain continuously... Replace both user interface and main control board due to software corruption
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jan 31, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher.... Continuous flashing light an a beeping noise half way through cycle then dishwasher stops!! Help! X
Check your sink drain to see if you dishwasher is able to exhaust water out. The exhaust drain hose, or the drain is plugged. They get debrea from food being washed off the dishes.
Nov 19, 2012 | Dishwashers
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
The dishwasher did a full cycle three days ago yet today it is just beeping and making gurgling noises now and will not start Any ideas as to what the problem might be
Check whether the water flow to the machine is OK. Try adding water
to the wash chamber manually and run the cycle. If the noise stops
it must be air trap. The machine should complete the wash also after this.
Still the problem continues the water pump to be checked.
Oct 04, 2010 | Dishwashers
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
416 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
