Bleach dispenser My wife and I just bought a house and it came with washer and dryer. Washer (LG wm0532hw) has an automatic dispensing system. The bleach dispenser does not dispense any of the bleach. I cleaned the dispenser according to manufacturer's owner manual and it did not help. The line running into the tub is not clogged because all of the other dispensers work properly. Do you have any suggestions?
  • 116 Answers
RU SURE ITS NOT WATER NOT BLEACH ,,THERE WILL ALWAYS HAVE WATER IN THAT DISPENSER
Posted on Nov 30, 2008
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Automatic bleach dispenser fills up with water during fill cycle
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
397 people viewed this question
Top Washing Machines Experts
