Question about GE Security Simon 3 Wireless Home Security System
I was woundering how you can progm. just one window/door contact for a entry delay. When I progm. the entry delay it does it to all my window/door contacts. and I just want the one progm. not all of them. It is a simon 3 security system.
  • 89 Answers
Hello, I have the Manuel for this particular system handy. If you are still looking for a solution, let me know. I will try and send it to you somehow
Posted on Nov 25, 2008
2002 pontiac bonneville locks and interior lights doesnt work
This may be a bad rear integrated control module. or connection or wiring to it.
REAR INTEGRATION MODULE (RIM)
The CTD system is an internal function of the rear integration module (RIM) which utilizes class 2 serial data and various switch input information to perform CTD functions. When the RIM detects an unauthorized entry, the RIM sends a message via the serial data circuit to the DIM to activate the horns and exterior lamps. The RIM has 5 basic modes. Disarmed, standby, delayed, armed, and alarm for operating the CTD system. The 5 modes transition from one step to the next in the following order:
When in the disarmed mode, ignition is OFF and any door is open the RIM commands the instrument cluster to flash the SECURITY indicator via the class 2 serial data circuit. The RIM has the CTD system in a disarmed mode until the following conditions are detected:
Ignition key turned to the OFF position
Any door open
Doors locked by either the power door lock switch or the LOCK button on the keyless entry transmitter
The RIM enters the standby mode when the above conditions are detected. In standby mode the RIM commands the instrument cluster to illuminate the SECURITY indicator via the class 2 serial data circuit. If all the doors are closed and the LOCK button on the keyless entry transmitter is used, the RIM enters the delayed mode.
When the last door is closed, the RIM enters the delayed mode for 30 seconds . In delayed mode the RIM commands the instrument cluster to illuminate the SECURITY indicator on steady via the class 2 serial data circuit.
After 30 seconds , the RIM enters the armed mode. In armed mode the RIM commands the instrument cluster to turn off the SECURITY indicator via the class 2 serial data circuit. Any forced entry activates the alarm mode.
IMPORTANT: The CTD system can be armed with the windows or sunroof open.
Jun 28, 2017 | Pontiac Cars & Trucks
2002 pontiac bonneville door locks and interior lights doesnt works
Any door open
2005 f150 4x4 power windows ,interior lights a/c ,radio gauges are not working fuses are ok and already check for voltage and it has but still not working . It has something else in betwen..?......
Checked voltage where ?
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
Symptom Chart Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • Instrument cluster module (ICM).
  • Accessory delay relay.
  • Driver window control switch.
  • Go To Pinpoint Test A .
Vehicles equipped with remote keyless entry (RKE) have an illuminated entry feature, which enables the instrument cluster module (ICM) to illuminate the interior lamps (and if equipped, the puddle lamps in the exterior mirrors) when an unlock signal is received from the vehicle security module through the UBP network, or when any of the doors are opened. The ICM controls the interior lamps illuminated entry feature by activating the battery saver relay. When active, the illuminated entry feature will be canceled when any of the following conditions are met:
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Instrument Cluster Module REFER to Section 413-01 . B2499 Courtesy Lamp Output Failure Instrument Cluster Module Go To Pinpoint Test A . B2659 Courtesy Switch Fault Instrument Cluster Module Go To Pinpoint Test C . - All Other DTCs Instrument Cluster Module REFER to Section 419-10 . Do you have a professional grade scan tool ? If not your best bet would be to take your vehicle to a qualified repair shop .
Oct 23, 2016 | 2005 Ford F-150
How do I reset the anti theft system on my Suzuki XL7? A new battery was installed and messed my system up
which one.
radio antitheft
car doors. (alarms) Content Theft Deterrent (CTD)
or immobilizer.
say what messed up means.?
the CDC system must be armed with the fob.
is that failing? I can not arm the system or it will not disarm. on my command?
my guess is arming. fails
  1. Turn OFF the ignition.
  2. Exit the vehicle.
  3. Important: The system is not armed if the doors are locked manually. The keyless entry transmitter or the door lock switch must be used to arm the CTD system.
  4. With a vehicle door open, lock the doors by pressing the LOCK button on the keyless entry transmitter or by pressing the LOCK button on the door lock switch. The system will begin the arm sequence when all doors are closed. The CTD system transition to the arm delay state when the final door is closed. The security indicator will illuminate steady when in the arm delay state.
    If the keyless entry transmitter LOCK button is pressed after the vehicle doors have been closed, the system will transition directly to the arm delay state with the indicator on steady.
  5. The system will arm approximately 30 seconds from the time that the system has entered the arm delay state. When the security indicator transitions to flashing slowly, the system is armed.
    Alternately, if the LOCK button on the keyless entry transmitter is pressed a second time, the system will arm immediately, bypassing the 30 second delay.
if this fails try the Second fob.
if the 2nd fob fails, then pull the battery neg lug, for 5 minutes
and put it back.
the full system rules are in the book called, FSM
seen here, read it for who to diagnosis this problem if it continues
just 4 bucks to read all facts
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
the book also tells you all things messed up with battery pulls.
good luck.
Oct 24, 2014 | 2007 Suzuki XL7 AWD
Can the Simon xt be programed so that when you enter the stay mode there is not exit delay beeps?
There is always the exit delay, however, you can arm it silently and with no entry delay. To arm silently, press Door and windows, press silent.
To arm without entry delay, press doors and windows twice. Press silent if also wanting no beeps.
Nov 04, 2012 | GE Security Simon 3 Wireless Home Security...
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
Simon3 entry & exit delay wont work.
It sounds like the door you are working with is progammed as a type 13 (perimeter) rather than a type 10 (entry exit)
Alarmprofessor.com
May 07, 2010 | GE Security Simon 3 Wireless Home Security...
Progm. window/ door contact
Hi, if you are talking about programming sensors into system the one for entry delay the rest for perimiter.
Nov 25, 2008 | GE Security Simon 3 Wireless Home Security...
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
93 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
