Question about Peavey 32fx USB 32 Channel Mixer
Missing parts for peavey pv2000 pwr amp
Garage sale purchase,one pv2000 amp i have both amp boards,and the large transformer also a case.Where may i purchase the other missing parts from?.
  • dj_glo Jan 30, 2009
    I also have a PV2000 amp, but with one blown "amp board" channel. Are you interested in selling me one of your boards so I can make the repair? Feel free to contact me.
    Thanks,
    Angelo Brisimitzakis
    evb209@lehigh.edu
    http://www.lehigh.edu/~evb209
  • dj_glo Feb 02, 2009
    I called Peavey's parts and repair department, and they explained the amp was discontinued in 2004 and they no longer have parts in stock.
    I'm hoping to find a replacement circuit board for one of the amplifier channels so I can repair the amp I have.
    Problem Solver:
  • 17 Answers
All parts are available from www.peavey.com
Posted on Feb 02, 2009
I have a Peavey Bandit 50 watt guitar amplifier that has no output with the exception of what seems to be a 60 cycle hum.
The schematic I grabbed from blueguitar.org shows several fuses in the power supplies. Did you check those, especially the one for the high voltage supply for the output tubes - fuse F1 on 'main board' ?
Feb 06, 2018 | Peavey Music
How do I connect the monitor speaker to a peavey 8500 power mixer
Mine has no designated monitor out, only two speaker output in back. You could use the preamp out/pwr amp out with headphones to monitor on front panel right side.
Jan 27, 2018 | Peavey Music
Needing a CIRCUIT DIAGRAM for a PEAVEY MP 400 AMP & an AMPLIFIER BOARD
Hello , Anonymous check here
http://www.manualslib.com/manual/498729/Peavey-Mp-400.html?page=8#manual
Sep 05, 2014 | Peavey Music
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Where can I get transformer for peavey rockmaster preamp 705-28703
Best to check out this place -- http://www.vibroworld.com/parts/tech17.html Give them a call and specifically let them know what you're looking for. Good luck!
Jan 12, 2013 | Peavey Electronics Peavey Rockmaster...
My pv2000 amp stop working on one side
Please add more background, which channel stop working?
As a blind advice, try to clean ALL back switches, including Stereo/Bridge Switch, let me know your results.
Oct 16, 2011 | Peavey Pv 2600 Power Amplifier
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
Peavey PR15D amplifier board. What is the part number of U5. The IC is damaged and can only read the beginning of the part #. Starts with HC.....
You can contact Peavey and they will send you the schematics. If you can tell me a few characters of what is on the chip I might be able to give you a clue. For power amps they often use the LM3886, an eleven lead power amp clamps to a heat sink. For typical small 8 lead op amps the often use 4560's.
Mar 22, 2011 | Peavey Electronics Peavey PR15D 15" 200...
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Peavey 32fx USB 32 Channel Mixer Logo
556 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
