Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Yamakawa 288K VGA
I have a Yamakawa 288K VGA DVD player. Accidentally, I changed something in its menu, and now I don't get any signal out of it. My TV just doesn't recognize any. Can you help, please? Thanks in advance!
Sincerely,
Aul
  • 4 Answers
Aul.
 You may have already tried this but try connecting the player via it's composite and component cables. It's possible you switched off your VGA connection in the menu and no image can be displayed. Worth a shot if you haven't done it already.
Posted on Apr 27, 2009
I am connecting a RCA DVD player (DRC277B) to my TV and have problems when using the HDMI cable. When I connect the unit using the AV Cable, things work OK. I then turned off everything and hooked...
Hi
Thanks for using FixYa. Two things that will cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the not available message. I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts
Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 15, 2010 | RCA Televison & Video
Playing a dvd from another region on Yamakawa dvd -275 dvd player
You may have to go into the Menu options and select a diff. region
Apr 19, 2010 | Yamakawa DVD-275 DVD Player
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Please find me a dvdplayer with vga port
My Yamakawa 288 with VGA out was discontinued a few years ago. I know that doesn't help you but Overstock is selling a MixSonic MS-1088(it comes in black or silver) with VGA out. I can't vouch for this player since I've never owned one. There also a few DVD players with VGA from a company called Vocopro. Again never played or even heard of these players before but Yamakawa players don't take up too many shelves in people's entertainment centers either. The MixSonic might be worth the $70 plus gamble.
Apr 08, 2009 | Televison & Video
Yamakawa 275 DVD Player
Possibly in the wrong output mode. (i.e. in PAL-60 when NSTC is needed)
On the remote, press the PAL/NSTC button to cycle through the output modes.   Choices are: NSTC, PAL, PAL-60 and AUTO.
Also make sure the correct TV type is selected in the System Setup menu.
Aug 10, 2008 | Yamakawa DVD-275 DVD Player
DVD player stopped working suddenly
my yamakawa is not wwork at all why?
May 24, 2008 | Yamakawa DVD-218 DVD Player
No sound when dvd plays
Menu choice settings:: many dvd players have the choice of
sound to tv only
sound to audio out only
sound to Digital out only
combinations of the above
check the settings in the menu and change to the sound output to the item actually caonnected
menu sequence unknown no product information given
May 03, 2008 | Yamakawa DVD-238 DVD Player
Universal remote
I found a perfect universal remote with the logitech harmony 525. usb / infrared / internet upgradeable. also loads keyfunctions directly from the old remote, but most of the keys came directly from the standards offered. the configuration is web-based and always up2date. service people are also very helpful. can fully recommend it!
Jun 26, 2007 | Yamakawa DVD-218 DVD Player
Yamakawa dvd 275
http://www.videohelp.com/dvdhacks.php?select=Yamakawa+275
Nov 24, 2006 | RCA DRC8300N DVD Recorder/VCR
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
