Question about Lexmark X4270 All-In-One InkJet Printer
Lexmarkx4270 all-in one
Lexmarkx4270 all-in-one inkjetprinter not printing from the black ink and also saying to check the tape or troubleshooting.lexmark x4270
  • kathye132 Nov 25, 2008
    i have the price for a answer, but no answer so what is the problems, or .
    you should try to please your buyer with the product that your buyer buy.
  • 128 Answers
Remove the black ink cartridge and examine the print head on it - you will probably find a small piece of tape (very thin) covering the jets - usually blue in color - remove it and reinstall the cartridge.
Posted on Nov 27, 2008
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
Not printing blak
Open up All printers and faxes by right clicking the printer icon in the system tray.On the maintenence tab check your black ink.Check to se if the tape is stil on the carftridge. If it is remove it. Printer should print black ink once the tape is removed.If it is removed. Try changing your black ink for a new one. Also sometimes your ink may not be compatible. Make sure you use compatible ink
Jan 29, 2011 | HP Office Equipment & Supplies
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
I replaced my black ink cartridge, but it won't print black. I did take the tape off the cartridge.
check your printer settings (properties) to see whether it says "pause printing" or "offline"
Nov 02, 2008 | HP DeskJet 950c InkJet Printer
Installed black print cartridge will not print now?
nope, there should be no tape on the cartridge. This is preventing the ink from coming out.
Jul 30, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X1270
Does the printer attempt to print? Did you replace the black or colored ink? If it was the black ink will it print in color?
If it prints in color, check the black ink cartridge for tape residue on the gold contacts. The blue tape will sometimes leave the adhesive on the cartridge and not the tape. It cleans off easy with a soft cloth.
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Replaced the black ink cartridge and it comes up no printer cartridge.
As suggested a couple of minutes ago, with a fresh cartridge installed, disconnect power (unplug) and let the unit rest for an hour or so and then reconnect it.
This may clear an internal error register.
Apr 21, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
