Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Problem with igniter on GE gas stove top
All 4 Igniters are not turning off
  • 833 Answers
All surface ignitors are wired in parallel.  One of the knob units switches is shorting to ground.  Find the short...it might be spilled food or something else.  Be careful.  Try to inspect visually with the power off and remedy the problem.
Posted on Nov 26, 2008
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
All the igniters are clicking after cleaning - help!
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Ge profile stove top strikers stuck on
If water or liquid gets in the switch it can short the circuit and cause the igniters to fire.....try pulling the knobs off and hairdrying the switches..i had one that sparked for 2 days before they finally stopped. good luck :)
Jun 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove top not lighting - gas is on/electic to appliance is ok
Is it a (relatively) new stove - i.e. piezoelectric spark igniters?
If so, is there a "lite" or "pilot" (or some such) position on the knob? On most stoves you have to turn the knob to that position, it starts clicking, you may smell a little gas, and then it lights.
Is that happening?
When you turn it to the lite position, can you see a little spark in burner. Often these igniters stop working and need to be replaced.
Let me know.
Mar 13, 2008 | Kitchen Ranges
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
