Question about Sony Handycam CCD-TRV37 Camcorder
Tape will not eject
I cannot get the tape to eject on my TRV-37. I noticed when I put it in the mechanism went 1/2 way down, paused and then went the rest of the way down. Now I beleive it is "eating" the tape. I get the flashing symbol to eject, but the mechanism won't move when I push the eject button. I do hear it making noise like it normally does. Help. Thanks!
  • Chuck Benslay Jan 05, 2007
    It turns out the tape had a problem. One of the wheels was misaligned. I was able to get the camera apart and get it out with a little bit of force. The door is a little misaligned and I have to use a rubber band to keep it completely closed but it works fine. I wasn't gonna spend as much getting this 8 year old camera fixed as I could spend to get a brand new digital camera! Thanks for the help though.
  • 89 Answers
This mceahnism is now defective and only a skilled workshop technician can do this job. If you need the service manual and parts we can help. Siva videolabs@gmail.com
Posted on Jan 05, 2007
Tape stuck, Mechanically Eject
Try staring up the camera while hitting the rewind button
Oct 29, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
My sony hi8 Handycam TRV 138 gives me a message reinsert tape What is wrong? do it need repair
The cassette is not being detected when the tray is landing. If the head is not spinning but you are getting the cassette ejected then it is a malfunction of the loading mechanism. Even if the tape end detection optocouplers are defective the fault could be so.If you can check this out then try and test the voltage before and after the cassette loads. there should be a change if not replace. check on the loading mechanism too. Hope this helps. Good day
Jun 28, 2010 | Sony Hi8 Cleaning Cassette / Head Cleaner...
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
DVR TRV-27 is showing error C:32:11
The problem is a rubber tape tension roller. Simply eject the tape, look inside where the tape goes. You will see a black rubber cylinder that may have a white plastic tube protruding. If you have long tweezer or a hemostat remove the plastic tube which hold the rubber tensioner in place, then remove the rubber tension cylinder. Clean the shaft of the black rubber tensioner with alcohol on a q-tip. Replace rubber tension cylinder and plastic tube.
Also, the tapes can cause the problem. This process is possible by one person, but you may need another person or have three hands. The C:31:23 is tape tension error. The tape has become stuck. Simply eject the tape. Holding the tape upside down, pull back on the tape cover release slide on the left side of the tape, now take the hemostat and push the tape release tab, located opposite of the tape cover, push this tab down and back toward the back edge of the tape. Now while holding both those release levers, take a pencil and wind the tape past the bad spot or until the tape winds freely.
I did both of these and was able to use the camera again and view all my tapes!
Good luck and QUIT SPANKING YOUR CAMERAS!!!!
May 01, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
249 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
