Question about Maytag MGR5751AD Gas Kitchen Range
Dishwasher i white how do i turn it black - Maytag MGR5751AD Gas Kitchen Range
  • Robert Artiaco Nov 25, 2008
    sorry i was messing around with the site figuring stuff out and now i cant get rid of this listing
    President:
  • Maytag Master
  • 2,651 Answers
Problably too expensive to change all the component over to black but if you provide the model number of the unit i will look up the parts and prices specific to your machine
Posted on Nov 25, 2008
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
Where on dishwasher is power supply? like how do we connect to power?
You connect your incoming 120v supply to the black and white wires on your d/w. the black and white wires are located at the bottom of your d/w on the right hand side in a small box. You may need 1/4in nut driver to open the box and there you will find your white(neutral) and black(hot power) wires located
thanks.
Dec 12, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
MY DISH washer electric supply wires are cutdown and water pipe of dishwasher cutoff and i want its diagram input which is help full to connect the circut
Hi .. the electrical input to the dishwasher should be a 3 wire cable, black, white, green/bare. The connection is generally into a small metal box just behind the kick plate on the right side of the front of the washer. The cable gets run thru a cable connector to keep the presure off the connection. The connection is black to black, white to white, green/bare to a ground screw in the connection box.
Jun 21, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
I currently have a black mdb4100aw dishwasher - can I replace the black front panel with a white panel?
YOu can find white panels, black panels, stainless panels, colors, and designs at www.applianceart.com. They have covers you can adhere over your existing ones too. applianceart.com
Mar 16, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
I was given a dishwasher and need to know how to install has only two wires
The wires on the Dishwasher should be Black and White
Black Wire is the Line or HOT Wire
White Wire is the Neutral Wire
Green Wire From the House goes to the Frame of the Dishwasher.
There might be a screw in the box area that is conected to the frame of the dishwasher and this will be the ground. ((((( The metal frame of the Dishwasher ))))
Feb 21, 2010 | Dishwashers
No power to New Frigidare dishwasher
there should be a cut off at the dishwasher .. usually a light switch or something similar that cuts power at the dishwasher only. Check to make sure that you have that turned on.
Dec 31, 2008 | Dishwashers
I am installing a dishwasher. When I went to wire I had only two wires a white and blue comming through the house wiring and a white and black from the dishwasher. Does blue go to black. White to white...
If you have a volt/ohm meter you can check for Power on the Blue wire. Or you can open the face of your fuse box and look to make sure the Blue wire is connected to the fuse. If it is, just hook up your Black from dishwasher to the blue from house. White to White ( Neutral). There is no real way to ground the dishwasher if your house wiring is a 2 wire (old) system. You shouldn't have a shock hazard if the wires are in the junction box for the dishwasher.
Bill
Jun 22, 2008 | Dishwashers
Maytag MGR5751AD Gas Kitchen Range Logo
46 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
