Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice maker wont make ice
We have a Maytag french door, freezer on bottom Model MFI2568AEB
it just stopped making ice a couple of weeks ago and we can't figure out why. We can get water out of the door so we know water is getting to it and yes the ice maker is turned on and the plastic thing is in the down position. I have read a lot about the water tube freezing up how can I go about trying to thaw it out if this is the problem? Not happy with a frig that was purchased in April of 07 and stop working already. Hope you have some solution for me.
Thanks,
Deb
  • 7 more comments
  • Anonymous Dec 27, 2008
    i get water but no ice what is wrong with the piece of ****
  • Anonymous Jan 03, 2009
    Not making ice but have ice in freezer bottom. Water output minimal.
  • grlf Feb 09, 2009
    MY MAYTAGMF12568AES STAINLESS STEEL BOTTOM FREEZER FRENCH DOOR REFRIGERATOR STOPPED MAKING ICE YES IT IS ON AND WATER IS ALSO COMING OUT THE DOOR BUT NO ICE. HELP
  • Anonymous Feb 13, 2009
    I get water from the door but we do not get ice.
  • mdejesu221 Mar 25, 2009
    Model mfi2568aes, not making ice, water works fine, auger in ice maker works- just no ice. I replaced the main board less than a year ago because front display going haywire and door flapper opening and closing. Now, no ice.
  • gregadlink Apr 03, 2009
    SAME PROBLEM!!! I CHANGED TEMP AS SUGGESTED, WAITING TO SEE... HOW LONG?? HOPE THIS WORKS
  • coleman9752 Apr 04, 2009
    I have the same problem, only I can see that the water intake bucket just below the water tube has frozen full of water. I think this happened because we have needed to replace the filter so water has been coming in very slowly to fill the ice tray, and now it has all frozen up. I'm wondering if anyone knows how to get to the back of the ice maker so we can thaw out that frozen ice, so that water can come in. Right now we have just turned the whole fridge off, but then we risk losing everything in the freezer. I'm so disappointed in this fridge, that I spent lots of money for in 2007, and it doesn't make nearly enough ice. We don't usually have enough and definately don't have enough if we are entertaining!
  • TIGGER4PRES Apr 08, 2009
    WATER WORKS BUT NO ICE.
  • Anonymous May 08, 2009
    From what I have read...you should set the refridgerator temp at no more than 38...freezer at -2 otherwise you will end up with spoiled food quicker. Initially our freezer was set at zero, but the ice wouldn't freeze quick enough before falling into the tray...then the cubes would freeze together resulting in a large clump of ice. Our refridgerator is now set at 36 with refridgerator at -2 and we are having the same problem with little ice development (possibly due to refridgerator being set too low). I am going to try to up the temp to 38 to see if that helps with the ice production. I also know we need to change the water filter, so that may be the problem, too. I will try to make it back to this site in a few weeks to let you know if the ice production improves.
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Posted on Feb 16, 2009
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
The icemaker on my Maytag Refrigerator MFD2560HES bottom freezer with French Doors has not made any ice for about two weeks. Before this, it would go for a few days and not make ice and just when I was...
Mine (same model) does the same thing. The only way I get it to work is to open the freezer, and move the metal ice lever arm up and back down again. Then it starts. But after a day, the arm stops moving and it breaks. I can't stand it anymore.
Before moving into my new house with the mfd2560hes, I had to replace an ice maker in my whirlpool refrigerator. So, I guess I'll be googling this maytag model and buying an icemaker motor replacement kit.
if I'm successfull, I'll post it here.
May 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
May 22, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
807 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
