Question about Brady VERSAPRINTER W/SOFTWARE Thermal Label
Brady versa printer won't print.
The tape got rolled up under the cutter and after I cleaned it out, it won't print anymore. Just feeds a blank
4 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: Where can I get a Brady LS2000 labelmaker
Staples might be able to direct you or fix it.
Posted on Dec 09, 2010
  • 112 Answers
SOURCE: I have a brady versa printer which powers up and
Here is the link to the software i can find for the different brady printers
http://www.bradyid.com/bradyid/downloads/downloadsView.do?default=true
Let me know if that is not what you are looking for. I am exactly sure what kind of info you are looking for.
Posted on Mar 08, 2011
SOURCE: I have a Brady ID PAL label maker, I was printing
Hello, this is a response from Brady's technical support team. Please try this:
The three contact pins in the printer are not making contact with the smart cell computer chip (the shiny silver pad at the bottom of each cartridge). The occurs after the printer is dropped or after shoving
cartridges in at an angle.
To remedy, remove the cartridge and look at the bottom of the cartridge opening (just above the Power button). Take tweezers or needle nose pliers and pull slightly on the pins (outward, and towards you). Please double-click and View the file below for a picture of the pins. Once these metal contacts are out far enough to make contact with the smart cell (computer chip) on the label/ribbon cartridge, the printer will know that labels are loaded.
In addition to the Insert Labels error, contacts that get pushed in can result in two other issues:
One, the printer will only print if the cartridge is pushed down
(which makes the smart cell touch the contacts).
Two, if one or two, but not all three, contacts are not all the way out, the printer may only print on half of the labels (because it is only reading some of the silver bars on the cartridge's computer chip, and narrow media activates only one or two bars, where as wide
media activates all three).
We'd be happy to help you directly if needed. Brady Technical Support is at 1-800-643-8766 ortech_support@bradycorp.com. Please leave your name, and phone number or email address, if you are unable to speak to someone. Our Technical Support business hours are Monday through Friday, 6:30am to 6:30pm US Central Time.
Hope this helps you!
Posted on Jun 15, 2011
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
HP DesignJet 110 - will not move cutter after job is printed
for paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
Jun 10, 2008 | HP Designjet 110plus nr InkJet Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
In the paper and quality options I have only sheet or CD/DVD to select from. Roll option is not showing
The Roll Paper button cuts, feeds and returns paper to the printing position when the automatic cutter is used. When held down for three seconds, it reverses the roll paper out of the printer. The cutter can make either one cut precisely between images, two cuts with a margin between images or no cuts. The driver lets you select which method you prefer. The Utility program has an alignment option for the cutter that you should use whenever you reinstall the cutter.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Epson Stylus Photo 1400 Printer
I have a Brady ID PAL label maker, I was printing labels and the printer stopped working< I thought it was because the cartridge was low so I replaced the cartridge and it still does nothing, I can hear...
I had the same problem. I opened up the unit and found that the small drive gear had lifted up on the shaft and was no longer engaging the other gear. I could have probably noticed this from the battery compartment. I pushed it back down and now the unit works fine.
Mar 10, 2010 | Brady ID PAL Thermal Label Printer
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Brady VERSAPRINTER W/SOFTWARE Thermal Label Logo
118 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
