Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
External hard drive makes sound like second hand watch
I bought the silver external hardrive NXnexxtech last year, i didn't use it for like 3 mos, now that i plug the usb, it makes a sound like fast clock seconds sounds. whats this means. does it stop by itself or not.
tnx
  • 64 Answers
You have two motors in a hard drive. The spindle motor that spins the platters and a head position motor. In your case the heads can't tell where the tracks are, so they keep swinging, until they hit the stop. This gets noticed, the controller retracts the heads all the way to the center, and it tries again. What you are hearing is the heads hitting the stop that keeps them from moving off the platters completely. Your drive is almost certainly toast. If the data is really important, you can send it to a disk recovery place, who will charge you lots of money, and send back the data on CD. If it's not, you buy a new drive.
Posted on Nov 25, 2008
My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Jan 13, 2011 | Western Digital My Passport Essential...
I've had my console for about a year now, and a couple weeks after i bought Halo Reach, as i was playing online, it said "Could not write, possible problem is that you have removed the hard drive or memory...
the problem may come from the hard drive which means that it may have a virus like a computer or that the hardrive may have a malfuntion and cant be able to read to the xbox 360 so it is considered to buy a new hardrive and recover your profile/ enter xbox.com to get all the downloads that was on the last hard drive
Sep 30, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Exterinal hardrive wont show up on computer
Try it in another computer, if it doesn't work on anoither computer, it may have died
Apr 17, 2009 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Wont read ext hard drive...says bad sectors...
Have you tried goggling for data recovery software. There are a lot of free ones if you had that to your search. But, I've used several paid for ones that worked. I'd try to trail versions to download and first see if can read the drive. If it can't the next thing I would do, is to dismantle the case around the hard drive, and take out the physical hard drive and switch the back pins to Slave, and add it to your computer. (make sure you have your main drive as Master) Then as a slave drive you have a lot more options to recover data.
Good Luck
Mark
Feb 23, 2009 | Western Digital My Book Essential 500GB...
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
When watching DVR recordings, the playback freezes
One of two things may be occurring. The first is a Line Of Sight issue may have been created if you have a limited LOS by wind moving foliage interrupting the signal. This will usually be preceded by pixelization or blocking appearing on the screen. The other instance is the hard drive in the receiver is faulty and in need of replacement. I will almost certainly assure you it is the latter of the two. You can upgrade the receiver to gain the ability to use an external hard drive to download your recordings so that the next time you need a receiver replaced you won't lose your recordings. The other benfit is that if you get a receiver tht does not have a DVR but is able to use an external hard drive you will save the cost of the DVR fee each month which in a year will save you thirty one dollars as there is a 39.99 one time charge to turn this capability on. In the first year alone you will have recouped almost the entire cost of the one time fee and in the second year will have probably recouped the cost of the external hardrive also.
Thanks for using Fix Ya. If you need further assistance please let me know.
Jan 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Purchased about two months ago. the external drive turns constatly making a grindin sound.
You need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Jun 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Won't function
Firstly it sounds as if the drivers aren't loading properly, right click on your drive (right click my computer> properties> hardware> device manager). Look for your external drive, rightclick and click update driver and force it to look in your cd for driver files. Secondly make sure you are connecting to a USB2 port, as it may not recognise the hardrive.
Oct 25, 2006 | Plumax PM-350U2-PCS V4 Silver Slim USB 2.0...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
226 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
