Question about Tomtom GPS
Can the GO720 have voice activation? - Tomtom GPS
  • 64 Answers
Voice activation is not a option on the GO 720 model. I found a forum of users that give you plenty of information regarding this unit and its features. http://www.gpsreview.net/forums/viewtopic.php?t=1674
Posted on Nov 25, 2008
Lifetime activation on a go720 Possible?
You will have to call customer support to get it fixed. They may even supply you with a new code to properly activate your device.
Mar 02, 2015 | Tomtom GO GPS
I have forgot my password on tomtom go720 how do
OK remove the Battery from inside, and look for a little "Hole" and push a ... say, a straightened Paper Clip and press it, hold for a second or so, & reassemble. You should be all good.
Feb 12, 2010 | Tomtom GO 720 GPS Receiver
New application download has screwed it up
delete the aplication from tomtom home i think that the option was called remove items
May 04, 2009 | Tomtom GO 720 GPS Receiver
TomTom go720 computer voice stutters street names
Hi Guys,
This is a problem with the application v8.300
if you are using a map v8.XX or higher you will need to wait for the next appilcation update which should fix this.
if you are using a map vv7.XX or lower, you can remove the 8.300 application from your device and download v7.481 by updating your tomtom again, this will revert your application to an earlier version which you can use until the next application is released.
Hope this helps.
Pabs
Jan 27, 2009 | Tomtom GO 720 GPS Receiver
Who do i turn voices off while listening to mp3s
If you go to change preferences you should see a voice preferences icon, tap it and you should see a disable voice with a red x over the icon. Just tap it and it should disable all of the voice instructions on the unit.
I say should since it works on my 720 and should on yours.
Regards
Jan 04, 2009 | Tomtom GO 720 GPS Receiver
Voice breaks up on tomtom
I had same problem with my Go720 I am using Kates voice, I uninstalled it and reinstalled in Tomtom home, seems to have cured it completely.
Oct 25, 2008 | GPS
There are no speaking directions on my TomTom GO720 e.g. for 'turn left' or 'take the next exit' or 'continue for 3 miles'. It only beeps for speed cameras etc. We have ticked all the boxes on the sound...
Hi there
As the TomTom is making beeping sounds, its a good indication that its not a hardware fault, it sounds to me its a software issue.
What you could do is try to reinstall the voices on your device. To do this, follow these steps:-
I presume you have TomTom Home installed already, if not you can download it from
http://www.tomtom.com/home
STEP 1 Make a Backup
  • Connect your TomTom to the computer and switch it on
  • Open TomTom Home
  • Click on 'backup and restore' and make a backup if you haven't done so already
Once the backup has been made, please do the following:-
STEP 2 Remove the existing voice files
  • Open My Computer, you will see the TomTom as two removable drives, one will be the internal memory and one will be for the SD card slot on the device.
  • Click into the Internal memory drive, you should see a whole load of files and folders.
  • You should see a folder called LoquendoTTS or Loquendo, click into this folder and delete the contents (all the files and folders inside the loquendo folder)
  • Go back to the root directory of the TomTom and delete the folder 'Voices'
STEP 3 Download and Reinstall the voices via TomTom Home
  • Go back to TomTom Home
  • Click on Add Maps, traffic and Voices
  • Select Voices. Loacate the voice of Jane and Tim and add them to your device
  • Go back to the main menu of TomTom Home, click on Add Maps, traffic and Voices -> Computer Voices and install the voice of Kate or Simon (UK English computer voices)
  • Close TomTom Home and also Close it from the system tray. (in the bottom right hand corner of your screen down by the computer clock, you should see a red icon for TomTom Home, Right click on it and choose 'exit')
STEP 4 Install the Clear Flash Tool from TomTom
  • Once Home has closed completely, please download and install the clear flash tool from:- http://www.tomtom.com/updates/clear_flash/clear_flash.exe (Home must be completely closed, otherwise it may not install correctly)
  • Accept the license agreement and keep pressing the Next arrow until the clear flash tool has installed.
  • Your device will start flashing to say there is some activity on your device
  • When your device has finished flashing on the screen (might take a minute), use the 'safely remove hardware' feature of your PC to disconnect the TomTom
  • Switch the TomTom off then take it out of the dock.
STEP 5 Test the voices
  • Switch the TomTom back on, but not connected to the dock
  • Let it load up to the main navigation screen
  • Tap onto the menu and tap onto 'Change Preferences -> Voice Preferences'.
  • Select a non-computer voice i.e. Jane or Tim and press test. You should now hear the voice instruction
  • Try selecting the voice of Kate or Simon i.e. the computer voices, and press test, you should now hear the computer voice.
This should get the voices working again, if not it might be worth giving TomTom Support a call and they can talk you through it.
Hope this works for you
regards
The Warlock
Sep 17, 2008 | GPS
Tomtom one not talking
same problem, have been told that Tomtom is saying nothing until he has his lawyer present, after being arrested for stealing a pig, Sorry for the joke.
My GO720 will not speak through internal speaker but have got round problem using radio or external speaker. (mine is out of warenty)
Jan 15, 2008 | Tomtom ONE GPS Receiver
GPS Logo
107 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
