Question about LG DLE2532W Electric Dryer
Drying cycles taking way to long
I am having to run the dryer twice on time dry to get the loads dry and they are still wet if I use sensor dry. Is there a common problem with these that is easily fixable?
  • 2 more comments
  • Anonymous Jan 04, 2009
    We went as far as checking the entire vent system, and it turns out that we had a MAJOR clog in our house. I got a Lint Eater dryer vent cleaning kit and removed 4 plastic grocery bags of lint from the tube. Now that the system is clean and free flowing, we are still having to run more than one cycle. Can someone help us with this? Thanks
  • jzgirl Jan 05, 2009
    everytime I use the sensor drying it says it should run (for eg.) 41minutes. When I check on the clothes it has shut off early and the clothes are still damp. Have to run cycle 2 or more times. Am now using the manual timed settings. The dryer is only 6 months old..seemed to be problem from start, but perhaps this is the norm??
  • mgonzalez69 Jan 28, 2009
    My dryer is having to run through 2 cycles just to dry the clothes and it sometimes doesnt even finish then. Also if it sould be the sensor drying how do you turn that off?
  • dmaxhd2 Feb 03, 2009
    I also have a LG dryer--takes a load of jeans and towels an hour and 20 minutes to dry on manual dry. Have had repair man out--bought extended warranty--and they told me that in Eurpoe where this dryer was manuf. they do not like their clothes all the way dry as americans do. i am also going crazy. Bought a new dryer so I can conserve energy, no i am using moe energy with a new dryer because it takes twice as long to dry clothes.
  • 1,028 Answers
Ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
Posted on Nov 25, 2008
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
Our new lg dryer model #DLE1310w is not drying properly. We have 6 medium side towels that are not very wet in the dryer even on the hottest setting it is taking two cycles to dry the towels. When we...
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Jan 17, 2010 | LG Dryers
How does may tag intelli dry work? what is the difference between less and more heat setting
there is a sensor inside the door to the right it actually "feels" the dampness of the clothes across the two strips on the sensor, if you close a wet washcloth in the door so that it hits the sensor you will see that it will show as wet and it will run longer.
if nothing in the load hits the sensor the sensor will call it dry and the load will finish, larger loads work better with sensor dry small loads not so much. if there is alot of trouble try using the timed dry cycle.
Sep 03, 2009 | Maytag PYE2300AY Electric Dryer
Loads have to run through high heat cycle twice to get completely dry. It was drying completely with one run through any cycle.
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Apr 14, 2009 | Whirlpool LER4634J Electric Dryer
Intelli sensor doesn't read that clothes are wet,just damp.does not get clothes dry in intelli cycle.does get them dry in timed cycle.already replaced sensor.
do you stack clothes on top? If so take them off and try another load and never ever put anything on top. It insulates it and makes the dryer not run right. Good Luck
Feb 27, 2009 | GE DBSR453EBWW Electric Dryer
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
LG DLE2532W Electric Dryer Logo
178 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
