Question about Maytag 24 in. MDB4651A Built-in Dishwasher
No water is coming to dishwasher
Installed brand new dishwasher today, hooked up all the hoses, water supply line is open, but when the dishwasher runs, no water goes in, what do i do?
  • Anonymous Dec 18, 2008
    I have a MDB4651AWB model and it was working fine. Now there is no water coming in when I turn it on to wash
    Sergeant:
    Champion:
  • 338 Answers
Check and see if you have 120 comming to the fill valve. if you do the start to loosen the hose you connected to make sure the valve actually opened when you turned the water back on
Posted on Nov 25, 2008
How to lengthen the water supply hoses. There to short to reach sink.
Buy a flexible braided hose for mains pressure. They come in different lengths.
Fit one end to the water outlet tap and for the other end you will need a fitting you can attach the dishwasher hose to that any plumbing supply has. I don't think you can buy a flexible braided hose that will fit to your water supply tap on one end and then straight to the end of the dishwasher hose on the other. You will need the adapter between the 2 to hook the fittings up. Use plumbers tape on the fittings when installing them for a good water seal.
Or you can just get a plumber in who will fit everything up for you and will also probably use a flexible hose to plumb in the water supply.
Jan 04, 2016 | Dishwashers
We're trying to install our dishwasher and there is a 3rd hose attached on the side. It appears to be a drain of some kind, part number, we think, printed on it is FRU 10967 19/07/04 08:33 Can you tell...
I just installed my Bosch dishwasher a few days ago and wondered about the same thing. The instructions for hooking up water supply and drain lines did not mention this third hose at all.
However, 'the third hose' (which appears open on the lower end, but loops up high) is attached at the other end at a point directly on the other side of the dryer wall from an opening inside the dishwasher, described elsewhere as a vent (somewhere in the manual we are advised not to place anything such that the vent could be blocked). I'm assuming that when water is pumped to the drain, since the chamber is otherwise sealed, there has to be an opening for it to breathe in air to replace the evacuated water, and conversely to allow air to leave when new water is taken in; thus both vacuum and pressure build-up are avoided.
So, although this third hose is not involved in installation, a little foresight by the manual writers would have had them mention it and put our minds at ease. Maybe we are not supposed to be curious....
Mar 19, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Connect water line and drain line
The supply line connects to the brass screw in fitting on the bottom left corner under the washer.
When you buy a dishwasher supply line kit, it will come with any adaptors needed. Unless you are using the steel braided line you will need to use teflon tape on the threads of the line. If you are using the SS line kit, you will only need tape on the adaptor.
Here is a pick of the line and the adaptor.
The drain line is attached with a typical hose clamp like this.
It is attached to the stub out on the garbage disposal if a GD is installed. If not then it is attached to the stub out on the drain pipe for the sink, like this.
Here is a pic of a drain line installed on a Garbage Disposal.
Oct 03, 2009 | Dishwashers
Dishwasher problems
the first thought that comes to mind is the valve... are you sure the water valve to the dishwasher is open?
The next possible cause could be a bad relay switch which opens when the unit calls for water... if it's bad the switch will stay closed and it won't fill up
Sometimes when the unit is brand new it may take several tries before it starts pumping water thru because the line needs to purge.
could also be a severe kink in the water supply line from the valve...
Sep 04, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Kenmore UltraWash Dishwasher is leaking from black hose...
No you will have disconnect the copper line. I would suggest that while you have it out that you replace the copper line with a braided stainless steel hose (also known as a dishwasher connector hose) If possible get a 60" or 72" hose so you can hook up the dishwasher when it is out and then push it back in with the water supply already hooked up.
Jul 31, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
there is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
May 29, 2009 | Dishwashers
Bosch dishwasher wont take in water through the cold inlet
First of all, the hot water line should be supplying the dishwasher, not the cold water line. That being said, if the machine is hooked up to cold water line, the only reason why no water is coming in would be that the valve is not open. Look under the sink to see if that is where the dishwasher line is attached to the cold supply. If not there, perhaps in the basement. Open that valve and you should have water.
Finally, if there is no water coming in and you have a lime deposit problem with your water it is possible that the line is full of lime and will have to be changed. good luck with this.
Feb 13, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I have a brand new Miele dishwasher which has worked grate since it was installed 2 weeks ago. It keeps shutting itself off & indicates an F13 fault. I looked in the manual, see that water is going in...
On my Miele 1220 dishwasher, the inlet filter is inside the inlet hose connector, where it screws onto the water supply. To clean it:
1. Turn off the stopcock. 2. Unscrew the inlet hose. 3. Remove the black rubber seal gently with a screwdriver. 4. Use pliers to remove the inlet filter. 5. Clean the filter under running water. 6. Replace the filter and seal. 7. Reconnect the inlet hose to the water supply, making sure the screw does not thread. 8. Turn on the stopcock slowly to check for any leaks.
Dec 06, 2008 | Dishwashers
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
Check the instruction manual, Smeg often use the program lights to give an error code.
You'll have to first ensure that the valve is open where the supply gets its water from the sink supply, and water is getting to the dishwasher. There is a garden hose type swivel adapter after the valve, right? Close the valve tightly- even if it scrapes the wood - and then unscrew that hose coupling and see if the hose is full of water. Look there for a strainer inside the hose that is clogged. Clean it. If that is good, reconnect and ensure it's tight.Open the valve. Now check the dishwasher to see if it's getting water. Then at the point where the hose enters the dishwasher is a spring loaded hose ring coupling, right? If not, and there's another garden hose adapter, remove that (after turning off the water again)and see if there's a strainer there. If water is supplied to the dishwasher okay, then it is probably the electric solenoid valve inside the base of the dishwasher.
Dec 03, 2008 | Smeg 18 in. DWF410SS Slim-Line...
How to install built-in dishwasher w/out kinking water lines?
I eventually unhooked the hotwater line where it comes in below the sink in order to give the slack I needed to hook it up to the elbow on the front of the dishwasher...then slid it into the 24in. space, but found that my hotwater line was 4 inches short! A trip to home Home Dept to buy more line and connectors solved the trick and now it is all hooked up and works with no leaks.
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag 24 in. MDB4651A Built-in Dishwasher Logo
131 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
