Question about Rio CE2100 MP3 Player
Volume knob damaged
The volume knob it´s not working after a blunt object hit the case,it got sunk into the case and it also spins,but it is not working. Maybe it just need to be resoldered but I don´t know how to de-assembly the case. Thanxs!
  • rodrigo vazquez Jan 09, 2007
    Well, my warranty expired a long ago, but I finally fixed it using the directions to open the case.Check the following link, it refers o a different model but the case is the same.
    http://www.greghughes.net/rant/PermaLink...
    Opening the case leaves scratches and scars on it and it´s not quite easy (took me 1 hour and a half to open the case), and the player it´s not the same after the "surgery".I found that the knob won´t need to be resoldered, but glued in oder to work again:you´re right,they work great but the knobs are just too fragile.
    If you decide to glue it,be careful not to use to much adhesive (I used a cyanoacrilate adhesive and the tip of a screwdriver to apply it ,avoid silicon).
    Too much glue may smear the knob assembly and may get stuck.
    Now for the power button:that´s easier but still you have to open the case.Under the button there is a micro-switch,the plated button pushes the micro-switch and it´s jointed with two little spikes, so maybe the plated button it´s just shattered and a little glue will do the job.
    Good luck,here´s my emal address in case you need more info:
    rvazquez1@axtel.com.mx
My first sons rio c2100 did the same thing . I needed to return it in the mail for the warranty exchange for a refurbished one.Is your warranty still in ? I hope so . If not , they will tell you to buy a referbished one for 99.00 .CRAZY !!! I had bought 2 (for my 2 sons). Now, my second son's power button won't work. The button is really loose and wiggley. He dropped it from only 4 inches onto a carpeted floor .I cannot find anyone to fix this for me . The design on these are absolutely stupid. Do you have any suggestions for me??
Posted on Jan 09, 2007
Sound cuts off, but if I touch the master volume contorl knob it comes on for a short time. Do I need a new knob, or something else?
Possible that there is fault in the preamp analogue/logic control. When you touch the volume control knob the static from you partially injects the circuit to work and thereby conduct to produce the volume.
The volume controller is an analogue rheostat coupled to a circuit that can be the suspect , it can even be a fault- open circuit- of the controller.
You can remove the top cover after disconnecting the power supply and check behind the volume knob for the circuit. If you are able to test this circuit , it will confirm the case.
Oct 07, 2011 | Teac AG-D9100 Receiver
I have a denon 1801 and the master volume goes to +60 which is all the way up and i cant seem to lower it, the knob turns and everything else works just fine
First solution would be to try and use the remote. If the remote is able to, the problem is in the knob. If the remote does not work, the problem resides in the volume board.
The problem resides in the circuitry that the knob is controlling. Unfortunately this knob has a full range of motion, which means that it is simply controlling a computer chip within the unit. (i have an 1801 as well). What has happened is that some component on the volume board has gone bad, which is resulting in your non functioning volume knob.
Unfortunately this is usually a job for a professional.
If you have standard electronics skills (soldering / disassemble / reassemble), you can open the case and find where the volume knob leads to. There should be a smaller board, and see if you can access it. Usually they are rather hard to get to, or to get free to actually see what is going on. The best solution would be to find a parts receiver, and swap boards. This shotgun approach changes everything. Otherwise, look for any damaged components on the board. Swap out any components that are damaged, or appear damaged with comparable replacements.
Mar 15, 2011 | Denon DRA-685 Receiver
Loses power in spin cycle
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
Apr 03, 2010 | Kenmore HE2 Plus Front Load Washer
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
The one with the volume/off knob works, the other
This problem is more than likely to be caused by damage to the wire going to the secondary speaker. For example if the speakers have been moved around alot, the wiring can get twisted and cause a break internally. Therefore causing a short. This may not be the case with your problem but I hope it helps
Nov 16, 2009 | Dell A215 Computer Speakers
Volume knob doesn't work. When I turn volume down, it goes up.
Internal volume switch broken (if somebody hit the knob )or jut need cleaning.
Oct 05, 2009 | Arcam Audio Players & Recorders
I am having problems with the volume knob. The
That is a dirty pot switch.. The volume adjusting pot gets dirty.. Two things to try..
1.) With the unit off - spinn the volume min to max many many times at a rapid pace.. This sometimes will displace the debris in the pot..
If that does not work --
2.) Get some "tuner cleaner" in a spray can.. At Radio Shack or a similar store.. Lay the radio on its back so the volume knob is facing up.. Pull the knob off carefully.. Use short controlled bursts of the spray.. A few sprays and spin the knob min to max several times and repeat..
Good luck..
PLease dont forget to rate for your free question..
Aug 20, 2009 | Lasonic TRC-931 Cassette Boombox
1997 bose volume
While radio is turned off spray electronic contact cleaner behind volume knob while rotating knob . Make sure you have rag handy .
Mar 15, 2009 | 1997 Nissan Maxima
How do i set the clock on my kenwood kdc-x492
you need to put the headunit in to STANDBY MODE then press he little DISP button to the bottom left of the volume knob. press it for a few seconds. then it will bring up a menu. hit the volume knob down a few times til you see clock set. then PRESS AND HOLD THE VOLUME KNOB IN THE CENTER then it will blink. press the volume knob up or down for hour i believe and left and right for minutes. Once thats done hit the src button again and its done!
Aug 21, 2008 | Kenwood Car Audio & Video
Lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Apr 22, 2008 | Car Audio & Video
Open Questions:
Rio CE2100 MP3 Player Logo
110 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
