Question about Insignia Digital-to-Analog Converter for Analog TVs
Remote came w/coverter, no codes for Panasonic TV/DVD/VCR combo
Purchased at Radio Shack. Cannot program the remote to work. No way to go through set up without remote.
  • catwild Nov 29, 2008
    Hooked up Box to TV and DVR. Everything seems to be working fine except the remote for the box. I put a new battery in it and the power on/off works on it, but I can't get the setup/menu to come up at all. Is the remote bad?
    I have the Zenith DTT901.
    President:
  • 2,992 Answers
Since you say the remote turns the box on and off properly, the control is probably working correctly. If you aren't seeing anything on the screen, you may not have the TV on the right channel (if you've connected it with an RF cable to the TV's antenna input jack). If you've connected the box using its video and audio outputs, you may not have selected the TV's video input.
As far as setting up the remote to work the converter box, that isn't necessary. If the remote is truly not working the box properly, and you have tried new batteries in the remote, you may have a bad remote or converter box and should take it back to the seller.
If the problem is setting up the boxes remote to work your TV, you may be out of luck. If you need to enter a brand code and your TV isn't listed, there is usually a code search function. The problem with universal remotes in general is that often they only give you control of a TV's basic functions but not advanced menu controls. The converter box remote may not be able to do more than just turn your TV on and off and control its volume. You may need to keep the original TV remote handy if you want to do things like adjust color levels, control closed captioning, or other functions like that.
Posted on Nov 30, 2008
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Radio Shack 5 in 1 remote has no p button
NOTE: To program a TV/DVD, TV/VCR/DVD, or TV/
VCR Combo, use the TV key.
1. Turn on the device (for example, DVD player)
and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/
DVD, CBL/SAT, or TV).
3. Press and hold P until the red LED blinks twice,
then release.
4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If
the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2
to 4 and try entering the code again.
5. Aim the remote at the device and press Power
(or Play, if it does not have a Power key). The
until you find one that works. If you cannot find
a code that works, see “Searching for Your
Code”.
6. Repeat steps 1 to 5 for each device you want to
control. For future reference, write down each
working device code in a safe place.
Sep 12, 2009 | Radio Shack (15-2147) Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Looking for the code for sylvania tv/vcr combo with a radio shack 3 in 1 universal remote
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
Mar 14, 2009 | Sylvania 6313CB 13 in. TV/VCR Combo
3-in-1 remote 15-2147
Have you tried these codes?
Toshiba TV codes: 0154, 0156, 0060, 1945, 1935, 1918, 1704
If your TV is a TV/DVD combo then use code 1935
Please follow "Programing a Device" on the product manul.
Feb 18, 2008 | Radio Shack (15-2147) Remote Control
Insignia Digital-to-Analog Converter for Analog TVs Logo
211 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
