Question about Pitco Frialator SG14 Deep Fryer
Heater thermo couple replacement
How difficult is it?
It is not dificult.
Posted on Dec 11, 2008
How do I make the flame of my water heater pilot bigger, it seems to little and goes out every day. I have installed a new thermo coupling but the pilot flame is small. Is there a place to increase th
If the pilot is going out, it may be from lack of combustion air intake. Make sure you have fresh air in the water heater room...one within 18 inches from the ceiling, & one within 18 inches from the floor. The size of the openings is determined by the BTU's of the water heater.
Dec 13, 2014 | Rheem Richmond 40 Gal Natural Gas 12 Year...
Wont stay burning if you let off ignition button
this could be a bad thermo coupling -- try and hold down the gas button for about 15 to 20 seconds while it is running and then let go and see if it stays running ( the thermo coupling needs to reach the proper temp ) -- if it shuts down after that then replace the coupling and all should be good.
c...
Feb 02, 2011 | Scheu (BG150T) Heater
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
I have a Rinnai model REH-18T-P that will not stay lite. The thermo couple looks to have a co monitor or other type wire on the thermo couple to connects back into the unit. Where do I find this thermo...
You probably don' need to start with the thermocouple. If the pilot is burning with a yellow tip and is curled away from the thermocouple. What you have is a dirty pilot. The heater thinks you have a low oxygen level because of lint or bug in the mixing chamber. With the pilot off, take a drinking straw and blow backwards thru the pilot opening. Then try again.
Nov 16, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
The heater will not stay lit unless you hold the button in. Thanks, Susan
Try cleaning the thermo coupling, sometimes soot will cover this and it cannot detect a flame, light abrasive sandpaper will work. ( The thermo coupling is what the pilot flame touches
Jan 04, 2010 | Stainless Patio Heater - Steel Outdoor...
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Wont Stay Lit
I would suggest that you replace the thermo-couple. It is a long, slender copper "wire" that runs from the control unit to inside of the unit. THe thermo couple's job is to regulate the pilot light and the lit flame as well.
They generally cost about $10 and take 10 minutes to replace. Some of them are reversed threaded (rights loosen, lefty tighty) and some of them are regular threaded (righty tighty, lefty loosen). TUrn off the gas supply at the meter or an external valve and remove the thermo couple by unthreading it at the control unit. Bring that with you to the hardware store (lowes or Homedepot) to make finding the correct one a simple task.
I hope this helps.
Apr 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pitco Frialator SG14 Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
