Often the CD tray will refuse to open. Have to do ahard restart to reboot the sysem.
  • 165 Answers
Hello the problem you have is an erratic switch or any interlock switch that it does not permit to open the door due is not finished the cycle ..firs try this after the cd is working push stop and then open door if it fails is out of time ...needs service for realign the cd system.........................saludos
Posted on Nov 25, 2008
Tray will not open on coby 978
Sorry, but my experience with CD, DVD players and recorders has taught me that, once the trays refuse to open, the unit is history. Kiss it goodbye. . .
Jun 05, 2016 | Coby Dvd978 5.1 Channel Dvd Home Theater...
Y cd driver wont open
just push the button on cd tray... then the tray will open. if won't read then maybe your cd is damage or the cd drive got in trouble unable to read. try restarting your system.
Dec 22, 2012 | HP Compaq nx9420 Notebook
The tray on my Arcam Alpha 6 CD player will not eject and refuses to budge. Neither the remote control nor the load button on the front of the unit will make it open.
It's either the gear on the tray loading mechanism or it's drive belt. The gear is made of a soft material and the teeth wear down on the hard tray rack. Get hold of Arcam and order TP21H replacement part and belt. The same happened to me and the gear had perished. In the meantime stick something onto the front of the tray that you can use to pull it open after you have pressed the 'load' key. Place your CD in the tray, press the 'load' key and push the tray closed manually. The player will work like this until you can replace the gear/belt.
Jul 04, 2010 | Audio Players & Recorders
My dell computer won't reboot. How do I reboot it from a cd?
If you are running Windows XP, open the DVD tray (if you could), then load the Win XP installer.
Restart the computer, and it will tell you to press any key if you would like to boot from CD.
Just hit any key and your computer should reboot using the CD.
Thank you and good luck!
Apr 26, 2010 | Dell XPS 200 PC Desktop
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
My laptop cd burner isn't burning music I downloaded anymore. Everytime I insert disc, made for music, it makes a weird noise says that a disc needs to be inserted (one is already in there) and the tray...
Go to "computer" and right click the drive,Then "properties"then "Hardware"then pick your drive,Then "properties"again,Then click"drivers"then "uninstall" and "OK".After uninstalling the drivers for that drive you need to Reboot,Windows will automatically reinstall and repair the drivers.If after all this work it still refuses to work it maybe a hardware issue,the drive could be bad.Sorry,.............
Jan 17, 2010 | Acer (SCB5265) Burner
The disc medio tray will not open and will not run on hp g60
Hi I'm Rain ,
Ok follow these instructions to reboot your CD Rom drive.
  1. click start then My Computer .
  2. In My Computer right click the DVD/CD rom drive icon .
  3. In the list , Click eject to see if the drive is being reconized .
  4. If nothing happens repeat steps 1-2
Now when you get to sep 3 you will click properties .
5. In properties click Hardware .
6. In Hardware click the DVD/CD device to highlight it .
7. Click properties .
Now look to the bottom of that window to see device status .
If it says , this device is working properly .Properties .
Next click Driver . In driver you will see a list of option tabs that allows you to , Roll Back driver Update driver and Disable driver .
The other option is Driver Details.
Click Roll Back driver to restore the driver back to the state before you added the latest program . Click ok and follow the screen instructions.
If this fails , you can follow these steps to get back to Driver and chose
Disable Driver . Click ok if another window pops up.
Now what you are doing is rebooting the DVD/CD rom drive.
This will restart all the drivers that are associated with the DVD/CD rom
device .
Now follow all the steps again to get back to Driver .
Now in Driver you will need to click Enable to restart the DVD/CD rom
device . Reboot your system and try the DVD/ CD tray to see if it responds . If it still fails to respond you most likely will need to replace or service the DVD/CD Rom Hardware { the Tray } .
Jan 08, 2010 | HP G60-230US Notebook
CD tray refuses to open when button pressed
its a gear or rubber belt and motor problem. check it. maybe stock up.
May 30, 2009 | Dell Dimension E521 (D10E16) PC Desktop
26 people viewed this question
 Grubhead
Grubhead
